Vazzle
Hello,
I have been getting regular BSOD when I am playing Games. In most cases it happens when I play Battlefield 3, Guild Wars 2 Beta and Warhammer: Space Marine.
I tried updating every Driver on my System but that didn't fix anything.
I also ran several Virus Scan with no result.
I bought this PC in March 2011, invested alot of money and now I am at the end of my abilities t to solve the problem on my own.
Help would be greatly appreciated.
System Specs:
-Windows 7 64-bit
-CPU: AMD Phenom II X6 1100T 3,3GHZ
-Motherboard: Asus Crosshair IV Formula
-RAM: Corsair CMX8GX3M4A1600C9 8GB (1600 MHz, DDR3, CL9, Kit4)
-Graphics: Sapphire ATI Radeon HD6870
Dump Files:
First make sure your machine is configured properly to facilitate the collection of .dmp files.
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be found later
Click OK twice to exit the dialogs, then reboot for the changes to take effect.
Then:
Please read the first post in this sticky thread here Link...
Then:
Please read the first post in this sticky thread here Link Removed
Do your best to accumulate the data required.
Run the SF Diagnostic tool (download and right click the executable and choose run as administrator)
Download and run CPUz. Use the Windows snipping tool to gather images from all tabs including all slots populated with memory under the SPD tab.
Likewise RAMMon. Export the html report, put everything into a desktop folder that you've created for this purpose, zip it up and attach it to your next post (right click it and choose send to, compressed (zipped) folder.
Additionally, if you haven’t already, please take some time and fill out your system specs in your forum profile area Link Removed .
Good luck
Randy
