Flash1945
All of a sudden my SRH icon stopped working. If I put the cursor over it, it says "Safe To Remove Hardware", but it never opens up. I have a internally connected multi-card-reader that should and did show up, but now doesn't (they show up under my computer).
When I shut down though, it does expand with a message saying their are no devices to remove!
Any ideas?:confused:
i'm having the same problem. i did some searching and found this freeware command line app:
Drive Tools for Windows
it's called 'RemoveDrive.' just type the following in the command window:
removedrive e:
replace 'e:' with the drive letter of your usb drive that won't safety remove. it works for me.
Same issue (or similar)
I too am having this issue. It used to work fine, but now no matter what I plug in, if I try to use the SRH it shows no devices to remove.
If I remove the device, I get no warnings to say "I should have stopped it, blah blah..."
Ken
removedrive e:
