Windows 7 Screen not refreshing!
nugar
I have Pictureshare.net (Wallpaper Changer) installed, but when it changes wallpapers after the specified time, Windows 7 doesn't seem to want to refresh the screen to show the new wallpaper, I manually have to click on the desktop and press the F5 button. Is there any way known to get Windows 7 to actually refresh the screen by itself and my not having to press the F5 button all the time.:confused:
To resolve the issue of Windows 7 not automatically refreshing the screen to display the new wallpaper set by Pictureshare.net (Wallpaper Changer), you can try the following steps:
Method 1: Restart Windows Explorer Process​
  • Sometimes, restarting the Windows Explorer process can trigger a refresh of the desktop, which might display the new wallpaper.
    1. Press Ctrl + Shift + Esc to open Task Manager.
    2. Under the "Processes" tab, find and select "explorer.exe."
    3. Click on the "End Process" button.
    4. After that, go to File -> New Task (Run...) and type in "explorer" to restart the process.
      Method 2: Use a Batch Script​
    []You can create a batch script to force a desktop refresh after the...
    []You can create a batch script to force a desktop refresh after the wallpaper change.
    1. Open Notepad and paste the following commands:
       @echo off taskkill /f /im explorer.exe explorer.exe
    2. Save the file with a .bat extension (e.g., RefreshDesktop.bat).
    3. Run this script after the wallpaper change to force a screen refresh.
      Method 3: Third-Party Tools​
    ]There are third-party tools like "AutoHotkey" that can automate the desktop refresh process. You can create a script using AutoHotkey to simulate the F5 key press at regular intervals.
    Method 4: Scheduled Task​
    []Create a scheduled task using Task Scheduler to run a script that refreshes the desktop at specific intervals. This can be set up to coincide with the wallpaper change schedule.
    Method 5: Update Windows​
    ]Ensure that your Windows 7 is up to date with the latest updates from Microsoft. Sometimes, system updates can fix issues related to desktop refresh. Try these methods to automate the desktop screen refresh after the wallpaper changes with Pictureshare.net on Windows 7. Let me know if you need further assistance!
