Hi Jim,
Sounds to me like you have your Start Menu set to
"Use Start full screen" option enabled (turned on). Try going to the same menu Neemo directed you to,
System Settings > Personalize > Start >Use Start full screen option and slide the slide button to
"ON". This may not work in v1607 (that's the old version you are attempting to upgrade from) to the new version, v1703. Microsoft did change the way the options worked at least 3 times since the July 29 2015 RTM release (first release of W10 to the public). Once you complete the v1703 update, this problem should go away! If it doesn't, you may have a corruption in W10 and need to run repairs, test your hardware, check for viruses/malware etc. Remember too, that since W10 is rapidly approaching 2 years since it's release in a month, that there are many viruses that now target W10 (with over 400 million users), and several of them target the Start Menu since it's so easy to screw up.
The other big thing new W10 viruses like to do is to shut off your Wi-Fi since if you have a laptop, it's pretty much a doorstop if you can't get Internet on the laptop once you leave your home.
If the situation continues on v1703 after your W10 update, first thing to do is for you to use whatever AV you have installed and scan/remove all viruses found. Retest for the problem. If it fixes it, you had a virus and have now fixed it!
If the problem persists, you could have a spyware virus. Visit
malwarebytes.org and download their free antispyware program, and scan/remove all spyware viruses found. Reboot & retest for your problem. Again, If it fixes it, you had a virus and have now fixed it!
Best of luck,
<<BIGBEARJEDI>>
