- Thread Author
- #1
Hello,
After the upgrade of 8.1 I got display issues because the resolution of Windows Apps (Metro UI, Internet Explorer, Login Page ...) has become lower than the resolution of windows. In my setting it is set at maximum level.
Here you can see the problem (and you can see that resolution of Chrome is at its normal level whereas resolution of IE is at a low level) :
Could you help me ? (sorry for the mistakes I'm french...!)
Thanks,
Thanks,
