Windows 8 [solved] Display issues after 8.1 upgrade (Metro UI)
JulieA
Hello,
After the upgrade of 8.1 I got display issues because the resolution of Windows Apps (Metro UI, Internet Explorer, Login Page ...) has become lower than the resolution of windows. In my setting it is set at maximum level.
Here you can see the problem (and you can see that resolution of Chrome is at its normal level whereas resolution of IE is at a low level) :
Could you help me ? (sorry for the mistakes I'm french...!)
Thanks,
I found where the problem comes from by chance when I wanted to change my lock screen !! :)
There is an option to set the "resolution" of Metro UI here :
It was set to "Default" and I set it to "More small"
And now you can see the difference :
Before : Link Removed
After : Link Removed
Great find...this will be very useful to others. Thanks for replying with your find/fix.
