nicholsml
Hello,
Recently, my computer's sound has started crackling. It has become worse and more frequent as time has progressed, and I am finally starting a support thread to help me resolve this.
The sound crackling is either mild or absent when I first restart my computer, but if I leave my computer on for longer, as time goes by, the crackling gets worse, until the point where sound is unintelligible, and utterly lags my entire computer, forcing me to restart.
I have been making music on FL studio 10 recently, and its at this point nearly impossible, as the crackling is annoying and slows down the rate of the song, as it lags everything. I try playing a non-graphics intensive game, and it will get a FPS of about 2. If i restart, i can get a steady 32 FPS again.
Not sure where this problem derived from, as I have updated my audio drivers to the most recent update.
My computer has also grown much more sluggish and is beginning to worry me, as i have a 1GB Radeon HD 4670 Video card, and games dont run at all at the quality level that they used to be able to handle.
I cant help but feel that my computer is slowly dying on me... Should I be worried that my computer will give up on me and I might have a hard drive crash?
I really need to know if I should be worried and how to fix this issue. Its been bugging me for quite some time.
I am currently running windows 7 on a Intel Pentium Dual CPU E2200 @ 2.20GHz 2.20 GHz processor.
I also had to start running my PC in windows 7 basic theme, as the Aero themes make my computer extrememly slow.
I dont think this should be normal, as my PC rating is 5.4.
It sounds like you're facing a few issues with your computer's performance, notably with sound crackling, decreased gaming performance, and overall sluggishness. Let's address these problems one by one:
Sound Crackling Issue:​
  1. Driver Updates: It's good that you've updated your audio drivers, but sometimes these updates can cause issues. Try rolling back to a previous version or reinstalling the current drivers.
  2. Background Processes: Check for any background processes that might be causing the sound crackling. High CPU usage can lead to audio distortion. Use Task Manager to monitor CPU usage.
  3. Audio Settings: Adjust the audio settings in FL Studio to ensure it's not causing conflicts with the system...
  3. Audio Settings: Adjust the audio settings in FL Studio to ensure it's not causing conflicts with the system sound settings.
  4. Hardware Check: Test the sound with headphones to see if the issue persists. If it doesn't, there might be a problem with your speakers or audio output.
    Sluggish Performance and Gaming Issues:​
  5. System Health Check: Run a diagnostic tool like Windows Memory Diagnostic to check for hardware issues.
  6. Temperature Monitoring: High temperatures can lead to performance issues. Monitor your CPU temperature using software like Core Temp.
  7. Graphic Card Compatibility: Make sure your Radeon HD 4670 drivers are up to date and compatible with the games you're running.
  8. Disk Cleanup: Perform a disk cleanup to free up space and improve system performance.
    Windows 7 Aero Theme:​
  9. Performance Impact: Aero themes can be resource-intensive. Using the basic theme is a good idea for improved performance on older hardware.
    Concerns about Hard Drive Failure:​
  10. Backup Important Data: It's always a good practice to regularly back up your important data to prevent data loss in case of hardware failure.
    Overall System Health:​
  11. Regular Maintenance: Ensure your computer is free of dust and well-ventilated to prevent overheating.
    Conclusion:​
    While your system might be showing signs of age, there are steps you can take to optimize its performance. However, if these issues persist and your worries about a hard drive crash increase, consider backing up your data and consulting a professional for a more in-depth inspection of your hardware. Feel free to try out these suggestions, and if you need further assistance, don't hesitate to reach out!
