- Thread Author
- #1
There seems to be a small problem here.
My speakers work fine normally, but I was using Skype, and when they answered the call, it popped up with No Speakers Detected. I then tested my sound using the 7 Volume Control, and it made no sound.
I then ended the call on Skype and sound resumed to normal.
It's the same problem with my in-built Mic.
It also does this on Windows Live Messenger. I don't know what the problem is, but I'd like to fix it asap.
If you need it, my laptop is Compaq Presario CQ61-107TU
and oh, thank you to everybody who helps out in advance.
