sandyocean
Honorable Member
I checked with my software Treesize (which is so useful) and I see that I have 626 GB of my laptop just used up on System Volume Information.
I just wondered if anyone can tell me if this is normal? It seems to be taking up much of my storage capacity. I only have 904 GIGS total!
I only have 148 GIG space left after removing everything that isn’t vital – onto my external drive.
Suggestions please?
Yay!! That was it. THANK YOU EVERYONE A MILLION TIMES OVER. It had created heaven knows how many System Restore points but when I went to a Systems Restore there was only ever a couple showing.
It wouldn't let me copy even one file in my Treesize (so I could check what it was) and computer wouldn't let me access the Systems Vol inf. (Even though I went into Computer and ticked show hidden folders). But with all the good tips here - I followed this -
What Is the “System Volume Information” Folder, and Can I Delete It?
And have deleted it via the Systems Restore box, as you guys suggested. I set it at one percent. Bingo. I have all my laptop space back. So grateful to you all for your time and trouble.
Neemobeer
Windows Forum Team
The 'system reserved' volume shouldn't be more than 500MBs in size so it couldn't exceed that. If by "system volume" you mean the C: drive then yes that can grow, but there isn't really a normal. It's going to depend on what you do and what kind of data you have. Music, movies etc. I usually run Disk Usage du.exe /accepteula -c -v -q C:\ >> %userprofile\Desktop\du.csv then sort the report and you can see what directories are taking up a lot of space
Well you can configure the storage for restore points up to many gigabytes so check your not set to something crazy.
I always set mine to 1%:
An image from 'System Vol Info using up huge Gigs'. Windows System Protection settings show configuration and disk space usage for restore points.
sandyocean
Honorable Member
Thank you everyone. Much appreciated.
I have only 2 System Restore points, so its not that. I go in and delete them. But thanks for info of how to set it to reduce it. I will do that.
I dont have much at all in the way of movies, couple of folders of pics and little music.
Treesize is the same sort of free software - I guess it does the same job as Disk Usage. And can delete it from there, which is useful. I have used it for years. I run it as Administrator. Treesize is where I got the information from about where my gigs are being used.
My Computer says ....145 gigs free of 904 gigs.
I have printed out and scanned the significant page that shows many file with lots of gigs! ATTACHED.
I have no idea what they are!!
Thank you for the screenshot.
According to your screenshot those are files of some sort, have you tried doing a search for one or two and seeing what they actually are?
sandyocean
Honorable Member
