Windows 10 task view wont clear
2weis
i have greyed out tiles in my task view foe 3 march. i have done malware scans and virus scans, security scans,shut down and restarted and this one date remains.
i tried disable task view but when it is enabled again same problem appears.
my thought was to remove and then reinstall task view but apparently this cant be done
any suggestion on how to clear this problem ( i am not very tech savy)
Brian
i had a tech guru look into it and he "deleted a file that runs in the background of task view and when the computer was restarted it re installed the file without the corruption"
