Windows 7 Taskbar problems
RAWowner333
I have come across some problems with the taskbar. I've pinned iTunes, Steam, Portal, Team Fortress 2 and Audiosurf (along with other things). The first day everything was working fine, but now there's problems. iTunes has the "unrecognizable file type" icon. When I click on Steam a new icon appears and it uses the half life icon and everything with steam is with the new icon. When I click on Portal and Audiosurf the same icon pops up at the end (so there's 2 icons for Portal or Audiosurf). The same thing happens with Team Fortress 2 but it uses the icon from Team Fortress classic. I don't even have that game. It doesn't really bother me, but I was wondering if there any fixes to it, because all the other programs I pinned to the taskbar are working correctly.
b46424
Are you using IE? I had the same kind of issue until I changed over to Firefox.
BlackWolf
isn't cs running as "hl.exe -game cstrike" ? so then it would be logical if it pops up as the Half-Life icon. same thing goes for team fortress. not sure about portal, I think that runs seperatly but is only using the HL2 engine.
RAWowner333
I don't have CS. it's nowhere on my comp.
Link Removed due to 404 Error
yeah..that's what it's doing.
icons are
itunes, steam, steam (opened), audiosurf, portal, tf2, audiosurf (opened)
Anthony.Tharayil
Hmmm......that's weird.... I had a similar problem (Steam worked fine, no icon problems) but once I installed Geometry Wars, anything Steam-related had the GW icon. After a little head-scratching, I realized that GW was pinned to the start menu.... so I unpinned it. BINGO! It's a beta so these things are to be expected.
Try back-stepping and look at the start-menu as well as the desktop and taskbar.
~ A.T.
Top Bottom
