gremlinkurst
System Specifications
OS1: Windows 7 Ultimate x64
OS2: Ubuntu 12.04 x64
CPU: AMD FX Black 6100 6-Core 3.3 GHz
MBD: GA-970A-UD3
GPU: MSI TwinFrozr III R7850 2 GB GDDR5¹
RAM: 4 GB DDRIII
HD0: 500 GB Seagate SATA III
HD1: 750 GB Seagate SATA III Solid State Hybrid
SCR: Acer S232HL LCD Monitor²
Native Resolution of 1920•1080 @ 75 Hz
¹Managed by AMD Catalyst Control Center w/ability to overclock CPU & GPU
²Managed by Acer eDisplay Management
Audio Specs:
AMD Hi-Definition Audio Device
Application: RealTek HD Audio Manager
Audio Driver Version: 6.0.1.06449
DirectX Version: 11
Audio Controller: HD Audio
Audio Codec: ALC889
My desktop speakers are Bose, and the sound is great, but when I try to use headphones of any kind, of any age, it sounds like I'm listening through Lilliputian outdoor speakers in my ears. When I have the graphic equalizer of the audio manager max on the deepest tones and minimum on the highest, the controls making a diagonal line from upper-left to lower-right, the sound is the best quality (I used no special effects or "environments"), especially when the headphones are not plugged in, but there is a marked deficiency in volume levels with the headphones, and it still sounds really tinny. The deficiency is SOMEWHAT mitigated when I use VLC Media player for music or video due to its ability to play audio at 125% loudness, but REALLY! I'm beginning to suspect that the software for my sound card was written by idiots. I've heard murmurings that RealTek's codec "blows." Is there an alternate audio manager I can download that will work with my hardware (I can't seem to determine EXACTLY what the audio hardware is)?
It seems like you're facing some issues with the audio quality and volume levels while using headphones on your system. This can be frustrating, especially when you're trying to enjoy your audio experience. Let's break down your system specifications and the audio setup to address your concerns:
System Specifications:​
  • Operating Systems:
  • Windows 7 Ultimate x64
  • Ubuntu 12.04 x64
  • CPU: AMD FX Black 6100 6-Core 3.3 GHz
  • Motherboard: GA-970A-UD3
  • GPU: MSI TwinFrozr III R7850 2 GB GDDR5 (Managed by AMD Catalyst Control Center with overclocking ability)
  • RAM: 4 GB DDRIII
  • Hard Drives:
  • HD0: 500 GB Seagate SATA III
  • HD1: 750 GB Seagate SATA III Solid State Hybrid...
  • Ubuntu 12.04 x64
  • RAM: 4 GB DDRIII
  • Hard Drives:
  • Monitor: Acer S232HL LCD Monitor (Native Resolution of 1920x1080 @ 75 Hz)
  • Audio Setup:
  • Audio Device: AMD Hi-Definition Audio Device
  • Application: RealTek HD Audio Manager
  • Audio Driver Version: 6.0.1.06449
  • DirectX Version: 11
  • Audio Controller: HD Audio
  • Audio Codec: ALC889
  • Desktop Speakers: Bose
  • Issue: Poor audio quality and low volume levels with headphones
    Troubleshooting Steps and Suggestions:​
  • Driver Update:
  • Ensure that your audio drivers are up to date. You can check for driver updates either through the RealTek website or your motherboard manufacturer's website. Installing the latest drivers can sometimes resolve audio issues.
  • Audio Manager Settings:
  • Experiment with different settings in the RealTek HD Audio Manager. Adjusting the equalizer settings or disabling any audio enhancements might help improve the sound quality.
  • Headphone Configuration:
  • Check if the headphones are properly configured in the audio manager. Sometimes, incorrect settings can affect sound quality. Make sure the headphones are set as the default playback device.
  • Alternative Audio Software:
  • If you're looking for an alternative to RealTek HD Audio Manager, you can try using third-party audio software like "Equalizer APO" or "Voicemeeter". These applications offer advanced audio controls and could potentially improve your audio experience.
  • Hardware Compatibility:
  • It's essential to ensure that the audio software you choose is compatible with your hardware. Since you have an AMD Hi-Definition Audio Device, verify if the alternative audio manager supports AMD audio hardware.
  • Technical Support:
  • If the issue persists, reaching out to the manufacturer's technical support for your audio hardware or motherboard can also provide valuable insights and potential solutions tailored to your specific hardware setup. By following these steps and possibly trying out alternative audio management software, you may find a solution that enhances your audio experience with headphones on your system. If you need further assistance or details on any specific troubleshooting step, feel free to ask!
