Laptop screen displaying a software interface with various blue icons and settings options.
Maintaining optimal performance on your Windows 11 system requires vigilance against certain common practices that can inadvertently slow down your computer. By identifying and rectifying these habits, you can ensure a smoother and more efficient computing experience.
1. Neglecting Regular System Updates
Failing to keep your operating system up to date can lead to performance issues and security vulnerabilities. Microsoft frequently releases updates that address bugs, enhance features, and improve system stability. For instance, the KB5053656 update resolved a bug causing Remote Desktop to freeze, and the KB5044384 update fixed issues with the Disk Cleanup tool. To ensure your system is current, navigate to Settings > Windows Update and click "Check for updates."
2. Accumulating Unnecessary Applications
Installing numerous applications, especially those seldom used, can consume valuable storage space and system resources. Over time, this accumulation can degrade performance. Regularly review and uninstall applications you no longer need by going to Settings > Apps > Installed Apps. Sorting by size can help identify large applications that may be impacting your system's efficiency.
3. Overlooking Startup Programs
Many applications configure themselves to launch automatically during startup, which can significantly increase boot times and consume system resources. To manage these, open Task Manager (Ctrl + Shift + Esc), select the "Startup" tab, and disable programs that are not essential during startup. This practice can lead to faster boot times and improved overall performance.
4. Ignoring Temporary and Junk Files
Over time, temporary files, system cache, and other unnecessary data can accumulate, occupying valuable disk space and potentially slowing down your system. Utilize built-in tools like Disk Cleanup or Storage Sense to remove these files. To enable Storage Sense, go to Settings > System > Storage and toggle on Storage Sense. This feature can automatically manage and delete unnecessary files, helping maintain optimal performance.
5. Mismanaging Power Settings
Windows 11 offers various power plans that balance performance and energy consumption. Using a power plan that prioritizes energy saving over performance can lead to sluggish system behavior. To adjust your power settings, navigate to Control Panel > Power Options and select the "High Performance" plan. This setting ensures your system operates at its full potential, especially during resource-intensive tasks.
6. Allowing Unnecessary Background Applications
Applications running in the background can consume system resources without your knowledge, leading to decreased performance. To prevent this, go to Settings > Apps > Apps & Features, select the application, click on "Advanced options," and under "Background apps permissions," choose "Never." This action stops the application from running in the background, freeing up system resources.
By addressing these six habits, you can significantly enhance the performance and responsiveness of your Windows 11 system. Regular maintenance and mindful management of applications and settings are key to a smooth computing experience.
Source: How-To Geek https://www.howtogeek.com/you-can-speed-up-windows-11-by-breaking-these-bad-habits/
