Chucktin
Well-Known Member
I'm working on networking our new-old (1995 vintage) house. It has already had some cable drops installed and all in the "wrong" places (well, duh).
I looked at MoCA (2 different coax cable sets already in the walls) - $180.00/cable run? - I don't think so.
Then I looked at MESH - interesting but ... Bluetooth communication between appliances? No thanks! (Burnt by BT already and once bitten twice shy!). Other systems are $ 5-600 for 3 pieces? Nope. My current Linksys router was dear enough.
The reason I was looking at MESH is that to get the drops I want & where I want I'll have to cut holes into dry-wall and deal with the blown-in fiberglass above the ceiling. PITA.
(Rant over, thanks for listening.)
Sent from my Pixel 4a using Tapatalk
It sounds like you're considering various options to network your house and dealing with the challenges posed by the existing infrastructure. Here are a few alternative or complementary suggestions that might suit your needs: 1. Powerline Adapters: - Powerline adapters are a simple and cost-effective solution to extend your network using your existing electrical wiring. They can provide a stable connection without the need to run additional cabling. 2. Ethernet Over Coax (MoCA): - If you have coaxial cable runs but don't want to spend too much on MoCA adapters, consider looking for more budget-friendly options or older generations of MoCA adapters, which might meet your requirements at a lower cost. 3. Wi-Fi...
It sounds like you're considering various options to network your house and dealing with the challenges posed by the existing infrastructure. Here are a few alternative or complementary suggestions that might suit your needs: 1. Powerline Adapters: - Powerline adapters are a simple and cost-effective solution to extend your network using your existing electrical wiring. They can provide a stable connection without the need to run additional cabling. 2. Ethernet Over Coax (MoCA): - If you have coaxial cable runs but don't want to spend too much on MoCA adapters, consider looking for more budget-friendly options or older generations of MoCA adapters, which might meet your requirements at a lower cost. 3. Wi-Fi Extenders/Repeaters: - Wi-Fi extenders or repeaters can help improve coverage in dead zones without the need for additional wiring. Place them strategically to enhance your Wi-Fi signal throughout your home. 4. DIY Ethernet Cabling: - If you're comfortable working with drywall and running new cables, consider a DIY installation of Ethernet cabling. It may require some effort, but it can be a cost-effective way to ensure a reliable wired connection where needed. 5. Hybrid Solutions: - You can combine multiple technologies to create a robust network. For instance, use a mix of Ethernet cabling, Wi-Fi extenders, and Powerline adapters to create a comprehensive network setup while avoiding Bluetooth-specific systems. 6. Professional Consultation: - If you find the installation process challenging or overwhelming, consider consulting with a professional network installer. They can provide insights and guidance on the best approach for networking your home efficiently. Each of these solutions has its pros and cons, so choose the one that best fits your budget, technical expertise, and networking requirements.
