.TXT files stuck on "System Information" as Current Default
[SOLVED].TXT files stuck on "System Information" as Current Default
Hi
I hope I can explain this properly!
I have somehow changed the default programme for .txt files to open with so when I double click on a notepad file it says "This is not a file type System Information can open" befoe then opening a System Information window showing my pc configuration, ie not notepad!
However if I right click on an existing .txt file and use "open with" Notepad then it is fine. And if I right click on my desktop and go to new text document it gives me a new one on my desktop, but if I double click on it I get the above problem.
I have gone in to "Set Associations" to change the associated program to notepad but it doesnt change it. It still shows "name" as .txt, "Description" as TXT file and "Current Default" as System Information.
Any thoughts would be appreciated?
Thanks
Jon
patcooke
Microsoft MVP
Microsoft MVP
It's not clear from your description but when you select "open with" do you select notepad and also check the box to always use notepad?
Hi Pat... if I right click on a txt file and go to "open with" and then "choose default program" it gives me 2 recommendations of Notepad and WordPad, but it does not let me put a tick in the "always use the selected program to open this kind of file"
patcooke
Microsoft MVP
Microsoft MVP
Mr
Have a look in the registry for this command:
HKEY_CLASSES_ROOT\txtfile\shell\open\command
It should have the entry:
%SystemRoot%\system32\notepad.exe %1
Re: Mr
Mine says @%SystemRoot%\system32\notepad.exe,-469 which doesnt match what you say. I assume I should try changing it to what you say and see if that sorts it out. If not I can change it back.
Re: Mr
I tried that Pat and it didnt change anything.
One thing I should have mentioned is that this started when I was trying to create an nfo file using a .txt file and somehow I must have changed the .txt files to open with System Information now.
patcooke
Microsoft MVP
Microsoft MVP
#7
Re: Mr
There's a pile of file association fixes which I've used for some time - they were written for XP but it's worth trying for this problem provided you back up your registry first - download from here:
Windows XP File Assocation Fixes
RAK
#8
Re: Mr
Open the atached zip and run the.reg. It will modify your registry back to the default.
patcooke
Microsoft MVP
Microsoft MVP
#9
Re: Mr
Yes - that's the one from the website I suggested - but do backup the registry first please!
#10
Re: Mr
Excellent... it worked!
Thank you both for your help... you have saved me a weekend of frustration for such a little thing!
patcooke
Microsoft MVP
Microsoft MVP
#11
Re: Mr
Glad it's sorted and thanks for the feedback.
RAK
#12
Re: Mr
Sorry Pat. I don't like horning in. I think I was probably typing my post when you planted this one. I didn't see it! But, FWIW, the original, now updated to Windows 7, is here.
Maybe you, like myself, are always experimenting? I have copied all of those associate fixes into a folder of my computer. Handy to have around!
File Association Fixes for Windows 7 - The Winhelponline Blog
patcooke
Microsoft MVP
Microsoft MVP
#13
Re: Mr
No problem - and yes, like you, I've built a library of these useful bits and pieces over the years.
