thiyagarajancs
Dear Friends,
I have installed WINDOWS 7 (Lisenced) in HP-LAPTOP. After that i can install all drivers. Then i can use all USB drivers. I am using 3 USB regularly. Then i installed VMWARE 7 . Now i cant use all USB drivers except 3 drivers. While connecting, It scanning "Searching Windows Update" then it shows the error "No driver found"
Please help me to solve this issue.
If you have a legitimate VMware, contact them. You're hardly alone with the problem. USB3 should not inhibit earlier versions. It's an "issue", and if they are serious about their business, they should have an answer.
Or, you have installed a somewhat nasty piece of software... Go to a Restore Point in Windows, Control Panel > System and Security > System > System Protection > System Restore, and choose a point before​ installing VMware.
