URGENT HELP NEEDED PLEASE
Discussion in 'Windows 7 Help and Support' started by Brutalcouture, Jul 24, 2012.
  1. Brutalcouture
    Brutalcouture New Member
    Jul 24, 2012
    2
    0
    NEED URGENT HELP ******
    I'm currently running Windows 7 16bit on my acer laptop but I have a CD for 32bit that I wish to install.
    When starting my acer laptop up, i press f2 to go into set up, but all that comes up is 'ENTER CURRENT PASSWORD' which confuses me.
    I've entered the wrong password in 3 times, and all it says is 'SYSTEM WILL HAULT' and nothing else happens.
    Help please!!
  2. patcooke
    patcooke Microsoft MVP
    Staff Member Premium Supporter Microsoft MVP
    May 16, 2010
    5,466
    269
    No such thing - do you mean you have 32 bit and are wanting to install 64 bit? What are you trying to do when you press f2 - get into the bios to set boot from the optical drive? If so it sounds like it may be protected by a password but there are usually "back doors" into bios systems - the bios on acer is usually a phoenix - if so the try the word "phoenix" (without the quotes) as a bios password.
Share This Page
Loading...
