Windows 8 USB Device not compatible with USB 3.0 whilst in an USB 2.0 port
StijnKuijper
Since a couple of days ago, my PS3 controller, which used to work just fine, decided to stop working with my PC. My computer does detect the device; I hear a sound when I plug it in and if I go to devices and printers in the control panel it's there. But if I go to device manager, I can't seem to find it, even when I click the "Show hidden devices" button. If I use the "Solve problems" in the control menu, it says the device is not compatible with USB 3.0, even though the device is in an USB 2.0 port.
MotionInjoy's DS3 Tool
This set is not for non-latency legacy systems i.e. windows xp, vista and 7 is the only support... you could try to email the guy but it looks to me as if he just stopped.
Option 1, get a new windows 8 ps3 device.
Option 2, install windows 7 on vmplayer (or workstation) and play your games on that... your old ps3c will be happy again.
+ vmplayer = free (the full version is workstation) and you can use your 8.1 system when not playing the games.
- hyper-v comes free with 8.1 and vmware doesn't play nice with it so you can't have hyper-v & vmware on the same boot.
StijnKuijper
Well, I used to use MotionInjoy's DS3 Tool, but that stopped working. After that I deïnstalled the drivers, and installed tried to use it without the DS3 Tool. But after I had deleted the drivers and the DS3 Tool, I wasn't able to find the controllers in the device mangers.
ussnorway
Windows Forum Team
