mtonumaa
Hello all
I keep my work files on a USB stick that is attached to my laptop. Several times a day a window pops up, showing me the content of the drive, as i had just connected it.
Why is this happening? It's a new laptop. Yes, i could turn off autoplay to "not do anything" when a pendrive is connected.
Never had this in Windows 7.
Probably a loose contact on your usb stick… In fact, I some times see the same behavior on my Nvidia Shield Pro which has an external hdd connected permanently. This happens usually only when I wake up the device to watch something. I suppose that the cause is just a loose contact, despite the fact that in my case I do not touch not the external hdd, nor the Nvidia device.
Sent from my SM-N975F using Tapatalk
GDany
Honorable Member
