vista problem
ok i have an asus p4p800s-x motherboard. i updated the bios bought 2 1gb sticks of ram. my cpu is a p4 2.8ghz dual core processor with hyper threading got a new video card an ati saphire x1650 pro agp 512mb video card cause i thought upgrading my pc from 512mb of ram and a 128mb ati radeon 9200 would stop these blue screen erros from popping up so i downgraded from vista to xp with my drive formatted and xp seemed to run with no problem so i re upgrade to vista and got a memory_management blue screen error during installation. which now it seems to install fine right now. it just bugggs me i do all this upgrading and still get blue screen errors on vista before downgradeing to xp. so im hoping formatting my drive and reinstalling vista will work. if not i dont know what is causing the blue screen when my pc is full of new hardware. aside from the cpu which i had in there for a awhile now.
i jus got a less than equal blue screen and theres this wiritng somekind of boot ini before windows starts its real quick but it has somethin to do with the boot ini i guess.
im starting to think my pc dont like 2gb of ram its the max it can take but when i take one out it works better. anyone know why that would be?
Windows Forum Admin
Usually that particular blue screen can be attributed to graphic drivers. Try downloading the latest version. You'll find a link in the multimedia section of the forum...:)
