Windows 10 Weird network problem???
Tare123
-Hi guys,so i turned on my pc,and i saw that i dont have internet connection. To fix it i opened the command prompt,and typed in three commands:
-netsh winsock reset
-netsh int ip reset reset.log
-ipconfig /flushdns
I did all of this and i didnt fix it,i've unplugged and plugged back in the ethernet cable,and still nothing.Then i reset my network config,and when i booted up my pc,this showed up in the network settings beneath the network status
An image from 'Weird network problem???'. Windows network settings showing network status with troubleshooting and adapter options.
!!!!!What do i do,i cant fix this and i dont have internet connection on my computer!?
Neemobeer
Windows Forum Team
I would run the network troubleshooter, it should fix most issues.
