What are normal cpu temps?
Discussion in 'General Computing' started by musiclover2000, Apr 21, 2016.
  1. musiclover2000
    musiclover2000 Active Member
    Mar 30, 2016
    38
    1
    Last week my computer shutdown from going to hot. I replaced the thermal paste and that helped some. Tonight I performed a stress test on my cpu from intel extreme tuning utulity for 2 min The temps were 91, 99, 88, 99 When not under stress the cores temps fluctuate but are around 61, 67, 70, 80
    I realize those stress temps are very high. The cpu passed the test, but are those temps anything to worry about? Would you recommend I replace my heatsink? I'm using a program called core temp.
    I'm running windows 7 with 2 GB memory and core i5 intel processor This is a computer I built in 2009
    Thank you
  2. holdum333
    holdum333 Banned
    Mar 27, 2016
    1,244
    148
  3. musiclover2000
    Mar 30, 2016
    38
    1
    Thank you!
    holdum333 likes this.
  4. holdum333
    holdum333 Banned
    Mar 27, 2016
    1,244
    148
    You are very welcome! Welcome to Windows forum. Hope to see you around. We have some great people here and I'm sure you will like it here.
    Join in on the threads.:beer_mug: You may get more replies latter from other members!
  5. Sonny
    Sonny Fantastic Member
    Nov 17, 2009
    1,294
    106
    What help me lower my temperatures was when I built my computer in 2012 I found a case that I could add up to four more fans. With that said my temps dropped quite a bit. I did put 2 140mm fans on the top and 1 120mm fan on the side. The fan on the side is drawing air in and the two on top is sucking it out. Here are what my temps are right now at the present. The core does go up when watching videos or playing online games but never has gone over 50. I have i5 2500k processor.
  6. holdum333
    holdum333 Banned
    Mar 27, 2016
    1,244
    148
    Very Nice @Sonny ! Thanks for helping! Here's my temps! I like your signature! "Never to old to learn"
  7. Sonny
    Nov 17, 2009
    1,294
    106
    These are my temps on my Toshiba Laptop with amd.
  8. holdum333
    holdum333 Banned
    Mar 27, 2016
    1,244
    148
    Very nice @Sonny ! Maybe I need to clean my vents my friend!:rofl: Thanks for the team work my friend!
  9. Sonny
    Nov 17, 2009
    1,294
    106
    Thank you holdum333, I clean mine out once a month using compressed air. I did use a air compressor to clean my computers out but it crapped out on me so back to canned air. lol
    #9 Sonny, Apr 22, 2016
  10. holdum333
    holdum333 Banned
    Mar 27, 2016
    1,244
    148
    Thank you my friend! I'm afraid I don't clean mine out that often; but I do monitor the temps and turn it up side down to look to see if there is any thing clogging my vents often!
    Thanks for your replies my friend. Is this a great forum or what?;):)
  11. holdum333
    holdum333 Banned
    Mar 27, 2016
    1,244
    148
    If you have a cat or pet; you need to check the vents more often.:rofl: I had to put my old cat down after 14 years. I loved that cat, but it was the best thing for me to do. A little off topic, but Mike will understand.:);)
    Good night friend!
Share This Page
Loading...
