Hi
If you are considering whether to buy a 32 or 64 bit system, then buy a 64 bit system.
Buying a 32 bit system now would be like buying a 16 bit system after 32 bit came out as the standard.
64 bit is the standard now, almost every new off the shelf computer is 64 bit.
Some day they will start coming out with 128 bit computers, then we'll go through this all over again.
As others have pointed out the main thing is ram, I don't think you can get many new computers with less then 4 and many come with 8, you have to have 64 bit for that.
My friend just got a new computer like mine but 2 years newer, and his computer has 16 gigabytes of ram, by the time I get a new computer it will probably be 32 or 64 gigabytes of ram.
I run a...
