dellic sekunde
Well-Known Member
Hello all, I found similar topics but not solution for mine, please help.
I connect to my home wifi and it says connected, but there is no internet connection.
I noticed that network adapter shows "wireless network connection 2" with that "2" at the end of name. I guess there is a problem. If I rename it to just "wireless network connection" it says it already exists. But cannot see it, and use it! Can anyone tell me how to reset it or somehow switch to "wireless network connection" without "2"?
Also when I type ipconfig/all I get this:
C:\Users\user>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : user-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection 2:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Dell Wireless 1510 Wireless-N WLAN Mini-C
ard
Physical Address. . . . . . . . . : 90-4C-E5-3F-2B-C6
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::7d98:b6f0:76fb:6f9e%15(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.5(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 01 January 2012 16:46:53
Lease Expires . . . . . . . . . . : 02 January 2012 19:09:45
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 345001189
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-98-7F-6C-00-25-64-74-D4-2B
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Broadcom NetLink (TM) Gigabit Ethernet
Physical Address. . . . . . . . . : 00-26-B9-0F-25-85
Tunnel adapter isatap.{2947BA03-3327-4E65-B736-14FB1ACB83E9}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.{7A2DD197-2CE7-4C78-B3DD-8862AE57AE09}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:8eb:30a4:3f57:fefa(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::8eb:30a4:3f57:fefa%18(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter 6TO4 Adapter:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #3
thanks in advance!
ard
rred)
thanks in advance!
