Windows 8 Window 8 Installation
Joey1394
Well-Known Member
I ran Windows 8.1 for about a week.
I tweaked the heck out of it, even with after-market software. Windows 10 despite it's flaws... is still better.
azajali43
Steps for window 8 Installation:
1. Insert the Windows 8 DVD or USB Memory key into your system.
2. And restart your computer.
3. When the menu appears, select the appropriate device to boot from.
4. Windows 8 Setup appears.
5. Select Language to install, Time and currency format, and Keyboard or input method and select Next.
6. Select Install Now.
RuskinF
Member
I have the steps to install Windows 8.1 on your system easy and pain-free. Here are they:
Windows 8.1 clean install.
  1. Turn on your PC so that Windows starts normally, insert the Windows 8.1 DVD or USB flash drive, and then shut down your PC.
  2. Restart your PC.
  3. Please setup language along with other preferences and click [Next].
  4. Click [Install Now] to start the process.
  5. Enter the product key to activate Windows 8.1 and click [Next].
I hope this helps!
