Here’s a concise summary of the situation as reported by PCWorld and corroborated by other sources:
A computer monitor displays a Windows desktop with various icons and an open system information window, set against a background of code.What Happened?​
  • Several recent mandatory Windows 11 24H2 updates (notably KB5060842 and KB5063060 in June) caused major stability problems for users.
  • Common issues included:
  • Error messages during update installs (codes: 0x800f0922, 0x80070002, 0x80070306, 0x800f0991).
  • Games (like Fortnite) and programs would randomly restart, FPS drops, and taskbar freezing.
  • Incorrect or noisy Windows Firewall event logging.
Microsoft’s Actions​
  • Microsoft has quietly acknowledged these issues.
  • In the optional preview update KB5062660, they specifically mention:
  • Stability fixes for issues that began with the May 2025 security update and subsequent updates.
  • A fix for Windows Firewall “Config Read Failed” errors (Event 2042 in the Event Viewer).
  • This update (KB5062660) is currently optional and must be installed manually via Windows Update or the Microsoft Update Catalog.
  • Microsoft will roll KB5062660 out to all users as a standard update on Patch Tuesday in August.
What Should You Do?​
  • If you’re experiencing these issues, manually install KB5062660 as a temporary fix.
  • If not, you can wait for the official rollout in August.
  • Microsoft claims to be working on stricter driver and update standards to prevent similar problems in the future.
For official instructions and details:
If you have questions about how to install the update or need troubleshooting help for specific error codes or symptoms, let me know!
Source: PCWorld Microsoft quietly fixed Windows 11 24H2 issues caused by past update
