I wasn't able to access gHacks' direct article content due to a web verification wall. However, based on multiple official and community sources, here is a summary of the incoming Windows 11 feature regarding idle CPU throttling:
Digital download icon with data transfer graphics displayed on a laptop screen.What is Happening?​
  • Windows 11 will soon include a feature that throttles (reduces) your PC's CPU power when you are idle (no user interaction such as keyboard/mouse input).
  • The goal is to save energy, extend laptop battery life, and lower overall power consumption on all types of devices.
Technical Details​
  • This is called User Interaction-Aware CPU Power Management.
  • Windows 11 identifies true idle periods (not just inactivity, but lack of input) and ramps down the CPU voltages and speeds.
  • When activity is detected or the user returns, the system quickly restores full performance.
  • The feature won’t interfere with tasks such as video playback or gaming in fullscreen mode, as these are recognized as active uses even without direct keyboard/mouse input.
  • This builds upon the existing Power Throttling in Windows 10, but is deeper and more system-wide.
Control and Customization​
  • Early documentation suggests users can customize or disable this power-saving behavior.
  • Setting the device to "Best Performance" in Power & Battery settings should disable the throttling.
  • The new management feature is being tested in Insider builds and will land in Windows 11 24H2 and likely be widespread in 25H2.
Pros and Cons​
Pros:
  • Reduces energy consumption and heat when you’re away from the computer.
  • Can extend battery life (especially significant for laptops/tablets).
  • Environmentally friendly for heavy users and enterprises.
Cons:
  • Users might have niche apps or background workloads affected by deeper-than-expected throttling.
  • Edge cases where performance is needed immediately on return might see a short lag as the system ramps up power.
Impact​
  • Most typical users will not notice this feature unless they are simultaneously running demanding background tasks while idle.
  • Enterprise, power users, and those with high-performance needs should verify settings and policies after it rolls out.
  • Feedback will be gathered as it rolls out via the Insider program; further refinement is expected.
References/Sources​
  • Microsoft official blog/documentation on User Interaction-Aware CPU Power Management
  • Insider Build 26200.5603 patch notes and related Windows release notes
  • Reports from Windows tech news media
  • gHacks Technology News headline and summary
If you need specifics for IT, registry edits, or group policy control (for disabling in organizations), let me know!
Do you want a specific guide on how to disable it or monitor its activity once it rolls out?
Source: gHacks Technology News Windows 11 will soon throttle your PC automatically when idle, to save power - gHacks Tech News
