WMP 12 pwns my CPU :-(
Discussion in 'Windows 7 Help and Support' started by gogogadgetearl, Jul 8, 2009.
  1. gogogadgetearl
    gogogadgetearl New Member
    Jul 8, 2009
    8
    0
    Since using the Win7 Beta (and now the RC), I've noticed that "wmplayer.exe" will occasionally run in the background without being explicitly started by the user. This wasn't much of a problem, but I thought it was odd. Since installing the RC, however, WMP often (>50% of the time that I am on my PC) hogs my CPU.
    I have a dual-core AMD Athlon X2 4600+. Right now, specifically, "wmplayer.exe" is bouncing from 30% to 55% CPU usage, meaning that it has pretty much taken over 1 of the cores on my CPU. I've tried ending the process, but it comes right back within a few seconds.
    I might be more forgiving of this if I understood what it was doing and why. Anyone out there know or have had a similar experience? FWIW, it's not thrashing the HDD, it's just hogging the CPU.
    Thanks for your help!
  2. gogogadgetearl
    Jul 8, 2009
    8
    0
    As for extraneous programs I've installed: Firefox 3.5 (fresh, not and upgrade), Starcraft, Warcraft 3 (+TFT), iTunes, ID3-TagIt. The latter 2 I've installed since noticing WMP's appetite for CPU cycles -- so they're likely not the culprit. Everything else is a fresh, default Win7 (x86) install.
  3. gogogadgetearl
    Jul 8, 2009
    8
    0
  4. JessicaD
    JessicaD New Member
    May 11, 2009
    396
    13
    Gogogadgetearl,
    You may also want to check with the source -- Microsoft -- directly for further responses from users. Microsoft does have an official Windows 7 RC Support Forum located here Windows 7 Category . It is supported by product specialists as well as engineers and support teams.
    Jessica
    Microsoft Windows Client Team
  5. gogogadgetearl
    Jul 8, 2009
    8
    0
Share This Page
Loading...
