Windows 7 Would appreciate help with this
Zalthoria
Well-Known Member
Hey I'm runnning win 7 64 bit and got some BSOD errors lately. A quick search around shows it could be a driver issue but im not sure what to do about it. Please help!
BugCheck D1, {fffffac0160ce108, 2, 0, fffff88002c5ce65}
*** WARNING: Unable to verify timestamp for e22w7x64.sys
*** ERROR: Module load completed but symbols could not be loaded for e22w7x64.sys
Probably caused by : e22w7x64.sys ( e22w7x64+6e65 )
Followup: MachineOwner
the...
yea:/ already i can see my non paged pool climbing and not going down.
An image from 'Would appreciate help with this'. Task Manager shows 47% memory use of 16GB DDR3 RAM at 4.32 GHz CPU load 11%.
Hmm... Well like i said I'm using very similar drivers to you in regards to chipset etc and I have similar figures. Why did you start focusing on the non-paged pool memory? Have you been having any issues in this regard?
An image from 'Would appreciate help with this'. Windows Task Manager showing CPU at 4% and memory usage at 27% of 15.9 GB.
What does your resource monitor say? Here's mine for comparison:
An image from 'Would appreciate help with this'. Windows Resource Monitor showing 26% memory use, multiple Chrome processes active.
Because previously my non paged pool would rise to something like 12gb. leaving me with only arnd 3 gb to work with and it would constantly crash my pc. and the hilarious part is that all i was doing is watching youtube.
An image from 'Would appreciate help with this'. The image shows a Windows Resource Monitor Memory tab displaying 48% RAM usage with detailed process memory stats.
alright ill give it a shot. but abck then when it came up to 12gb ram, you could add up the total amount of ram being used and it wouldnt hit that amount. Not sure if that is caused by ram leak too.
Ok bud, I'll be hitting the sack soon so will check back in the morning.
Aites!.
Anyway, I've done as you suggested but even after i turn off Fire fox, the memory doesnt look like it is released.
An image from 'Would appreciate help with this'. Two Windows tool screens showing memory usage and system performance details.
You can see that memory in use is 6GB, but is the resouce monitor, there isnt a particular program that is using up a huge amount of Ram.
If it helps, I'm using:
MSI Z97 gaming 5
Intel Core i7 - 4790k
MSI GTX 970 Gaming 4G
Samsung SSD 8520EVO
2x 8gb Corsair vengeance 2400mhz
Hey,
hmm.. your memory does look a little better tho, did you try rebooting once you'd disabled the browser? It is probably related to something your running rather than the os itself it's just a case of finding it.
I did a bunch more testing,
first i unplugged my lan and ran a few games, no changes in non paged pool.
when i plugged in my lan and did anything internet related, the non paged pool starts to rise,
i plugged out my lan and switch to a wireless usb, and the non paged pool remains the same.
I'm pretty? sure thats its cause of the killer network card. googling Z97 gaming 5 memory leak also yields quite alot of results, none of which conclusively pinpoints the problem though
is that the same as tthe non paged pool?
if so ive seen it hit 10gb,
if not, how do i check it ? :P
i think this is it.
P.s. i cant seem to find my crash logs on windows 10
Thanks for the above. The reason you can't find any dump files is because you've turned off the Pagefile for the C drive. You need a pagefile of at least 200mb but in any case I'd change it so that your running the recommended amount.
Why do you have a pagefile on the G drive?
This could be why your seeing some odd figures in the Task manager.
Hmmm for some reason its not letting me set System managed size on C drive. it told me to restart and when i came back it was back to the default. and it just hit 100% memory usage and my com stopped responding
