Windows 7 Would appreciate help with this
Zalthoria
Well-Known Member
Hey I'm runnning win 7 64 bit and got some BSOD errors lately. A quick search around shows it could be a driver issue but im not sure what to do about it. Please help!
BugCheck D1, {fffffac0160ce108, 2, 0, fffff88002c5ce65}
*** WARNING: Unable to verify timestamp for e22w7x64.sys
*** ERROR: Module load completed but symbols could not be loaded for e22w7x64.sys
Probably caused by : e22w7x64.sys ( e22w7x64+6e65 )
Followup: MachineOwner
the...
Ok you need to change it so that the Pagefile exists only on the C drive. As i said above this could be why you've been seeing odd stuff in the Task manager.
Here's mine for comparison:
An image from 'Would appreciate help with this'. Windows 10 system properties and virtual memory paging file settings displayed on a forum page.
Yeap ive made the change already.
still seems to be climbing,
though its at a slower rate.
An image from 'Would appreciate help with this'. Task Manager shows 58% memory usage of 16GB DDR3 RAM at 1600 MHz on a Windows PC.
after leaving youtube running for like 2 - 3 hours.
I'm not sure if that's good or bad that your showing me? Is it better or worse?
Does it happen on any other site?
well basically. the issue is still there. it happens whenever i use the internet. youtube is just a easier way to keep using the net
Well have you changed anything in regards to settings? I would turn all your settings back to their defaults. Something wasn't right because you had all those pagefiles so whatever it is you had changed you need to return to default.
When was the last time you did a clean install of Windows 7?
Personally I'd re-install, add my drivers and see how the machine performs. If all is ok start adding your third party apps you like to run but test after installing each one.
ive done several clean installs in the past 2 months and ive not changed any settings at all. i dont have much in the way of third party apps either.
PS. just had a bsod
BugCheck 50, {fffff84351502314, 10, fffff84351502314, 2}
Probably caused by : NETIO.SYS ( NETIO!NetiopIoWorkItemRoutine+3c )
this bugcheck can be caused by numerous things including hardware. As we have already tested a few things let's try the driver verifier although if you turn it on and get a bsod at boot you'll have boot into safe mode to turn it off. We just need to see if we can trap the driver which is possibly corrupting the system. Use the guide below and post any resulting dump files:
How do I fix a Blue Screen in Windows using Driver Verifier?
BugCheck C4, {2000, fffff80012bb8098, 0, 4f4e4558}
*** WARNING: Unable to verify timestamp for bflwfx64.sys
*** ERROR: Module load completed but symbols could not be loaded for bflwfx64.sys
Probably caused by : bflwfx64.sys ( bflwfx64+8098 )
well it's pointing to the Killer Wireless driver which is slightly out of date. Try updating to the latest version. If this issue continues it may be a possibility that something is wrong with the component itself.
bflwfx64.sys Fri Jun 19 20:53:10 2015: Bigfoot Networks Bandwidth Control Wireless Driver
You'll need to turn off your Anti-virus to install the above driver correctly.
Wireless/network driver it's just part of the same driver. Actually if you bsod again you could try breaking the wireless driver by renaming it to .old instead of .sys. Make sure you back the driver up (make a copy) before doing so.
Ran killercleaner and reinstalled the latest version. retested with verifier and BSOD still occured
BugCheck C4, {2000, fffff801fa4080b0, 0, 4f4e4558}
*** WARNING: Unable to verify timestamp for bwcW10x64.sys
*** ERROR: Module load completed but symbols could not be loaded for bwcW10x64.sys
Probably caused by : bwcW10x64.sys ( bwcW10x64+80b0 )
well this time it's caught a slightly different driver although it's still part of the Killer Network suite. If I'm correct it relates to the Killer Bandwidth control driver.
Has this bsod been present since you first purchased the motherboard?
The motherboard is relatively new correct?
Have you tried the 'standard' Killer drivers which basically means the software suite isn't included?
yes this issue ive been having has been since i bought the PC.
Its barely 3 months old
i've tried it before but from a diff site. I'll test it again and get post here
