BugCheck D1, {fffffac0160ce108, 2, 0, fffff88002c5ce65}
*** WARNING: Unable to verify timestamp for e22w7x64.sys
*** ERROR: Module load completed but symbols could not be loaded for e22w7x64.sys
Probably caused by : e22w7x64.sys ( e22w7x64+6e65 )
Followup: MachineOwnerBug Check 0x50: PAGE_FAULT_IN_NONPAGED_AREA (Windows Debuggers)Cause
Bug check 0x50 usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, be it main memory, L2 RAM cache, or video RAM).
Another common cause is the installation of a faulty system service.
Antivirus software can also trigger this error, as can a corrupted NTFS volume.
 Oh and I'd turn the verifier off now as it doesn't seem to be catching anything.
 Oh and I'd turn the verifier off now as it doesn't seem to be catching anything.There you go:XD this might be stupid but how do i do that?
