x64 ie problems!
I cannot get the following to install, any ideas why or the fix for this issue?
Update for Microsoft .NET Framework 4 on Windows XP, Windows Server 2003, Windows Vista, Windows 7, Windows Server 2008, Windows Server 2008 R2 for x64-based Systems (KB2468871)
Download size: 27.5 MB
Update for Microsoft .NET Framework 4 on Windows XP, Windows Server 2003, Windows Vista, Windows 7, Windows Server 2008, Windows Server 2008 R2 for x64-based Systems (KB2533523)
Download size: 37.5 MB
davidhk129
What is the error code when they failed to installed?
error code 643, 646 or 1603 ?
Code: 80070005
davidhk129
That code indicates you do not have admin rights, or not enough permission to install.
Are you the admin ?
See if this Microsoft article can help you.....
http://support.microsoft.com/kb/968003
The article suggest using Microsoft Safety Scanner.
Go ahead and use it.
After that install Malwarebytes (if you don't have it ) and run a full scan with Malwarebytes.
http://www.malwarebytes.org/products/malwarebytes_free/
Select the Free version.
