The thread is a guide to displaying customizable video or GIF wallpapers on the Windows lock screen, using Task Scheduler and either Topaz or Runsaver with a converted video executable for safer playback. It explains setup, security and compatibility trade-offs, audio and display behavior, and GIF conversion; no specific questions are raised, and the overall tone is practical and helpful.
Thread Author
2024 Update!
This guide is to show different methods to run live wallpaper on top of Windows Lock-Screen securely that include videos or GIF files. So it is customizable.
It takes 2 programs to get it to work as soon as the Screen is locked with the assistance of Windows Task scheduler. These methods work on Windows 11,10, 8.1 & 7 as well.
Read the entire guide to see which method is better for you so that you download the correct tools for it to work well.
The programs are no longer available from links because the links have changed and some of the programs cannot be found anymore so I have attached all of them for easier access.
The Winrar must be installed first to be able to access the required tools.
I had to split the Winrar because of the allowed upload file size limit of the forum. It might be required to update old version of Winrar if facing any issues.
Download both into the same directory and then open only one of them and extract the content into any directory.
Right click on one of the 4 RAR files and find the Winrar in the context menu and then choose: "Extract to All in One\"
Runsaver: is to run any program when screensaver is triggered. (This will replace any screensaver you might be using).
Nircmd: Used to run Screensaver as soon as the screen is locked in combination with a scheduled task.
Winrar: Used to extract the downloaded compressed files.
Topaz: Used to run videos as screensaver.
Audio/Video To Exe: Used to convert video files to EXE so that they run securely on the lock screen without giving access to any system files.
Extract Runsaver and add the two files called runsaver.exe and runsaver.scr to C:\windows\system32 folder and for 64bit windows also add it to C:\windows\SysWOW64 folder. (If it gives an error then extract the contents to a folder that you create on the desktop then copy the contents to that location).
Runsaver will create INI file in both directories which will be identical. If there are any errors then just search for all the runsaver.ini files under the windows directory and delete them, then add the program that you want again. (There might be more than 2 Runsaver.ini because windows will add the runsaver files to more directories)
To enable runsaver so that it runs the program when screensaver starts just select RunSaver as the windows screensaver from the same place that screensavers are selected for Windows. Select settings to add the video file.
Runsaver will run any program on the lock screen. However it will not be secure because it will give access to all files on the PC. The methods in this guide are done in a secure way so that no files can be accessed from the lock screen. Some programs will not run on runsaver if they are already running on the logon session. So close the program to work on the lock screen if there is an issue.
Extract Nircmd files and add them to C:\windows\system32 folder. (If it gives an error then extract the contents to a folder that you create on the desktop then copy the contents to that location).
To run the screensaver as soon as the screen is locked regardless of the delay assigned time then follow the below instructions. (Be aware that using this method will run the screensaver twice in a row in some cases).
Create a new task in Task Scheduler and choose a name that is related to the subject:
Under trigger choose new and do the same as the below.
Screenshot of “Edit Trigger” settings window configuring a workstation lock task for a specific user.
Under actions, choose new and do the same as the below.
For laptops and portable devices do the same as the below so that it works while on battery.
Screenshot of task scheduler “Conditions” settings for running a task based on idle, power, and network.
The two below methods are 100% safe and will not give access to files on the PC.
Method 1:
Using the Topaz tool.
Some video file formats might not work for this method.
Copy the content in the folder TopazMSS-1.1.1.0 to C:\windows\system32 folder and for 64bit windows also add it to C:\windows\SysWOW64 folder.
To enable Topaz so that it runs the program when screensaver starts just select "Topaz - the multimedia screen saver" as the windows screensaver from the same place that screensavers are selected for Windows. Select settings to add the video file.
This method will not allow audio of the video while screensaver is running.
The screensaver will not allow the screen to turn off if it has been preset to be turned off while the screensaver is running. To let it turn off you have to change a setting in the windows media player.
Change the settings as it is showing below in WMP to allow the screen to turn off at the normal preset time.
If this affects your usual video playback. Then you can download any other media player as there are many that are free that can be used as your default video player to watch your videos so that you can use this method.
Method 2:
Using Runsaver tool safely.
Download the program from the download link section
Any video can be used to work on the lock screen with runsaver but to keep it secure, convert the video to exe file from Audio/Video To Exe.
Some video file formats might not work with Audio/Video To Exe.
After adding the file. Select convert, then select EXE. In the configuration. Choose the file to work in full screen and in loop.
It maybe be necessary to run the "Audio/Video To Exe" as an Administrator. If getting error messages just keep trying until it works. Be slow when using this tool so that it works well.
The important fields are:
The Antivirus might block the exe file so just add it to exceptions if it is blocked then end task from the task manager and run it again if it does not work the 1st time.
The screensaver will not allow the screen to turn off if it has been preset to be turned off. It will turn off if you set it to Exit When audio /video is done playing plus the preset assigned time instead of loop while converting it to EXE.
Screenshot of a software “Options” dialog configuring playback and window settings.
Audio will work normally with this method but it might change the aspect ratio of the video.
To exit the screensaver press on ESC button or Q . Not sure how to exit from touchscreen devices that don't have a physical keyboard. If running another program on the lock screen then use Ctrl + Alt + Del to exit from it.
GIF files.
Use the below link to convert GIF files to video and then use it with any of the above methods.
Online GIF to MP4 Video converter
Upload the GIF file from Windows or add the exact URL for conversion.
To download the video. Select the 3 dots on the output video after it has been converted and select download.
The GIF files are limited to 50 MB for conversion from the website. If the speed is too fast in the output video then it can be edited to work better from the provided tools on the same website.
Johncoool
Thread Author #2
No need for the update because the main post has been updated!
It looks like you're sharing some helpful insights regarding the use of live wallpaper on the lock screen for Windows 11. It's always a good idea to ensure users have the latest tools, especially when dealing with features that require specific software. To summarize the key points: 1. WinRAR Installation: Before diving into live wallpaper, make sure to install WinRAR first. You mentioned that links may change, which is why you've opted to provide direct uploads. 2. Handling File Size Limitations: Since you've had to split the WinRAR files due to upload size constraints, if users encounter issues, it might be necessary for them to update to the latest version of WinRAR. 3. Extraction Process: Download all four files into the same directory and extract the contents from one of them. That keeps things organized and simplifies the process. 4. Running as Administrator: For the "Audio/Video To Exe" tool, running it as an Administrator can resolve potential permission issues, making the process smoother. If you have any specific links or files you intended to share with this post, be sure to upload them directly in the forum for easy access! Happy customizing those lock screens! If you have any further questions or insights, feel free to ask.
