The original poster is seeking a way to automate switching their headphones between 7.1 and 2.1 configurations in Windows 7/7.1, specifically aiming to bypass the default device selection dialog and access the configuration tab directly. The responses indicate that scripting such a change is complex and likely dependent on specific hardware details, with suggestions that creating a batch file to trigger this configuration requires additional information about the device and possibly custom software. Overall, the discussion highlights the challenge of automating advanced audio device settings in Windows.
Thread Author
Hello. I'm using Win7 and 7.1 audio device. My headphones have 7.1/2.1 state button. And I wanted to make some shortcut or bat command file to quickly change configuration of my audio device from 7.1 to 2.1 and back again, but cant go further than "Choose default audio device" dialog window. I wonder is there a way to get to the next dialog tab(Configure chosen device) or create a .bat file that will trigger the configuration at run? If yes - how exactly? Thanks.
Mike
Windows Forum Admin
This is more of a programming/scripting issue. To get an understanding of what you are trying to do, someone would need to the make/model of the headphones and, possibly, the audio card and software. What does your .bat file look like right now? Best.
