[langtitle=hu]Re: Random BSOD[/langtitle]
The firewall should be of the same brand as your antivirus. e.g. Eset Smsart Security.
What is a good firewall that i can replace zonealarm with that wont cause these types of problems?
Elmer
- Joined
- Mar 5, 2010
- Messages
- 3,864
Hi fnf99,
Your dump file gives a stop error of 0x7F. Its a stop error that ZoneAlarm firewall gives frequently. You have two (?) options:
ZoneAlarm Security and Firewall is known to be a cause of BSOD's on many Windows 7 systems. Download the Link Removed due to 404 ErrorUninstall ZoneAlarm through Programs and Features. Boot to safe mode and run the ZoneAlarm Remover. Reboot. Make sure that Windows Firewall is enabled.
Alternatively
Try this Microsoft hotfix if you wish to keep ZoneAlarm: Stop Error 0x07F when you run applications that transfer data using the UDP protocol in Win Server 2008 R2/Win 7" It may work, it may not.
I'll follow up with any other drivers that need attention.
Alternatively
Elmer
- Joined
- Mar 5, 2010
- Messages
- 3,864
Outdated Drivers. Update or Uninstall:
RTCore64.sys Wed May 25 07:39:12 2005 MSI Afterburner Known issues with Windows 7. Uninstall
Drivers with Updates:
ALSysIO64.sys Sun Apr 19 20:41:04 2009 Core Temp - CPU temperature monitor
RTKVHD64.sys Tue Sep 07 12:17:23 2010 Link Removed
If issues continue attach new dump files to a post.
Analysis
Drivers:
Analysis
UNEXPECTED_KERNEL_MODE_TRAP (7f)
This means a trap occurred in kernel mode, and it's a trap of a kind
that the kernel isn't allowed to have/catch (bound trap) or that
is always instant death (double fault). The first number in the
bugcheck params is the number of the trap (8 = double fault, etc)
Consult an Intel x86 family manual to learn more about what these
traps are. Here is a *portion* of those codes:
If kv shows a taskGate
use .tss on the part before the colon, then kv.
Else if kv shows a trapframe
use .trap on that value
Else
.trap on the appropriate frame will show where the trap was taken
(on x86, this will be the ebp that goes with the procedure KiTrap)
Endif
kb will then show the corrected stack.
Arguments:
Arg1: 0000000000000008, EXCEPTION_DOUBLE_FAULT
Arg2: 0000000080050031
Arg3: 00000000000406f8
Arg4: fffff80002c4aec0
Debugging Details:
BUGCHECK_STR: 0x7f_8
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from fffff80002c81ca9 to fffff80002c82740
STACK_TEXT:
fffff800`00ba4d28 fffff800`02c81ca9 : 00000000`0000007f 00000000`00000008 00000000`80050031 00000000`000406f8 : nt!KeBugCheckEx
fffff800`00ba4d30 fffff800`02c80172 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff800`00ba4e70 fffff800`02c4aec0 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDoubleFaultAbort+0xb2
fffff880`0d536f00 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!SeAccessCheckFromState+0x58
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!KiDoubleFaultAbort+b2
fffff800`02c80172 90 nop
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: nt!KiDoubleFaultAbort+b2
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4c1c44a9
FAILURE_BUCKET_ID: X64_0x7f_8_nt!KiDoubleFaultAbort+b2
Followup: MachineOwner
0: kd> !analyze -v
* Bugcheck Analysis *
Else
Endif
Arguments:
Debugging Details:
CURRENT_IRQL: 2
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: nt
fffff880`06131000 fffff880`0616f000 1394ohci 1394ohci.sys Tue Jul 14 01:07:12 2009 (4A5BCC30)
fffff880`00f07000 fffff880`00f5e000 ACPI ACPI.sys Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`01a00000 fffff880`01a8a000 afd afd.sys Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`061b6000 fffff880`061cc000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`0bbf2000 fffff880`0bbfa000 ALSysIO64 ALSysIO64.sys Sun Apr 19 20:41:04 2009 (49EB7E50)
fffff880`01391000 fffff880`0139c000 amdxata amdxata.sys Tue May 19 18:56:59 2009 (4A12F2EB)
fffff880`04552000 fffff880`04558000 AsIO AsIO.sys Tue Aug 24 02:53:02 2010 (4C7325FE)
fffff880`0454b000 fffff880`04552000 AsUpIO AsUpIO.sys Tue Aug 03 03:47:59 2010 (4C57835F)
fffff880`0945d000 fffff880`09466000 aswFsBlk aswFsBlk.SYS Thu Jan 13 08:37:10 2011 (4D2EB9B6)
fffff880`09423000 fffff880`0945d000 aswMonFlt aswMonFlt.sys Thu Jan 13 08:37:21 2011 (4D2EB9C1)
fffff880`01a8a000 fffff880`01a94000 aswRdr aswRdr.SYS Thu Jan 13 08:37:32 2011 (4D2EB9CC)
fffff880`04502000 fffff880`0454b000 aswSP aswSP.SYS Thu Jan 13 08:41:42 2011 (4D2EBAC6)
fffff880`01bec000 fffff880`01bfc000 aswTdi aswTdi.SYS Thu Jan 13 08:40:19 2011 (4D2EBA73)
fffff880`01159000 fffff880`01162000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01162000 fffff880`0118c000 ataport ataport.SYS Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`06780000 fffff880`067a0000 AtihdW76 AtihdW76.sys Fri Sep 24 06:44:48 2010 (4C9C3AD0)
fffff880`0580a000 fffff880`05fff000 atikmdag atikmdag.sys Wed Oct 27 03:29:53 2010 (4CC78EA1)
fffff880`0457e000 fffff880`045c9000 atikmpag atikmpag.sys Wed Oct 27 03:14:23 2010 (4CC78AFF)
fffff880`04000000 fffff880`04007000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`044f1000 fffff880`04502000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`08f56000 fffff880`08f74000 bowser bowser.sys Tue Jul 14 00:23:50 2009 (4A5BC206)
fffff880`055de000 fffff880`055e9000 btath_bus btath_bus.sys Thu Jun 24 07:17:43 2010 (4C22F887)
fffff960`00680000 fffff960`006a7000 cdd cdd.dll unavailable (00000000)
fffff880`041c8000 fffff880`041f2000 cdrom cdrom.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00cc0000 fffff880`00d80000 CI CI.dll Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`01b5e000 fffff880`01b8e000 CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00c62000 fffff880`00cc0000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0125e000 fffff880`012d1000 cng cng.sys Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`061a6000 fffff880`061b6000 CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`0970d000 fffff880`0971b000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`04450000 fffff880`044d3000 csc csc.sys Tue Jul 14 00:24:26 2009 (4A5BC22A)
fffff880`044d3000 fffff880`044f1000 dfsc dfsc.sys Tue Jul 14 00:23:44 2009 (4A5BC200)
fffff880`043d5000 fffff880`043e4000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01b48000 fffff880`01b5e000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`067dd000 fffff880`067ff000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`066a4000 fffff880`066e7000 dtsoftbus01 dtsoftbus01.sys Wed Dec 22 10:19:28 2010 (4D11D0B0)
fffff880`0971b000 fffff880`0972e000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`0405c000 fffff880`041b0000 dump_iaStor dump_iaStor.sys Tue Sep 14 02:23:32 2010 (4C8ECE94)
fffff880`0972e000 fffff880`0973a000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`05460000 fffff880`05554000 dxgkrnl dxgkrnl.sys Fri Oct 02 02:00:14 2009 (4AC5509E)
fffff880`05554000 fffff880`0559a000 dxgmms1 dxgmms1.sys Tue Jul 14 00:38:32 2009 (4A5BC578)
fffff880`05400000 fffff880`0544f000 e1c62x64 e1c62x64.sys Tue Sep 21 22:34:15 2010 (4C9924D7)
fffff880`013e8000 fffff880`013fc000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`0139c000 fffff880`013e8000 fltmgr fltmgr.sys Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`0142b000 fffff880`01435000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01b0e000 fffff880`01b48000 fvevol fvevol.sys Sat Sep 26 03:34:26 2009 (4ABD7DB2)
fffff880`01783000 fffff880`017cd000 fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff800`031ee000 fffff800`03237000 hal hal.dll Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`0559a000 fffff880`055be000 HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`055be000 fffff880`055cf000 HECIx64 HECIx64.sys Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`0978e000 fffff880`097a7000 HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`097a7000 fffff880`097af080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`09780000 fffff880`0978e000 hidusb hidusb.sys Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`08e8e000 fffff880`08f56000 HTTP HTTP.sys Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`01b05000 fffff880`01b0e000 hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`01005000 fffff880`01159000 iaStor iaStor.sys Tue Sep 14 02:23:32 2010 (4C8ECE94)
fffff880`0617b000 fffff880`06187000 ICCWDT ICCWDT.sys Wed Aug 18 09:27:45 2010 (4C6B9981)
fffff880`06190000 fffff880`061a6000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`00e00000 fffff880`00e21000 jraid jraid.sys Tue Aug 10 10:28:44 2010 (4C611BCC)
fffff880`06090000 fffff880`0609f000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`097e6000 fffff880`097f4000 kbdhid kbdhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00bc1000 fffff800`00bcb000 kdcom kdcom.dll Tue Jul 14 02:31:07 2009 (4A5BDFDB)
fffff880`04400000 fffff880`04443000 ks ks.sys Thu Mar 04 04:32:25 2010 (4B8F37D9)
fffff880`01400000 fffff880`0141a000 ksecdd ksecdd.sys Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`01758000 fffff880`01783000 ksecpkg ksecpkg.sys Fri Dec 11 06:03:32 2009 (4B21E0B4)
fffff880`06600000 fffff880`06605200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`060a1000 fffff880`060a4d80 LGBusEnum LGBusEnum.sys Tue Nov 24 01:36:48 2009 (4B0B38B0)
fffff880`0bb78000 fffff880`0bb7a480 LGVirHid LGVirHid.sys Tue Nov 24 01:36:48 2009 (4B0B38B0)
fffff880`097b0000 fffff880`097c5000 LHidFilt LHidFilt.Sys Tue Aug 24 18:21:36 2010 (4C73FFA0)
fffff880`09487000 fffff880`0949c000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`097d2000 fffff880`097e6000 LMouFilt LMouFilt.Sys Tue Aug 24 18:21:43 2010 (4C73FFA7)
fffff880`09400000 fffff880`09423000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c0a000 fffff880`00c4e000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`09772000 fffff880`09780000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`055cf000 fffff880`055de000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`097c5000 fffff880`097d2000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00ddc000 fffff880`00df6000 mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`08f74000 fffff880`08f8c000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`08f8c000 fffff880`08fb9000 mrxsmb mrxsmb.sys Sat Feb 27 07:52:19 2010 (4B88CF33)
fffff880`08e00000 fffff880`08e4e000 mrxsmb10 mrxsmb10.sys Sat Feb 27 07:52:28 2010 (4B88CF3C)
fffff880`08e4e000 fffff880`08e71000 mrxsmb20 mrxsmb20.sys Sat Feb 27 07:52:26 2010 (4B88CF3A)
fffff880`0118c000 fffff880`01197000 msahci msahci.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`01ba5000 fffff880`01bb0000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f67000 fffff880`00f71000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01200000 fffff880`0125e000 msrpc msrpc.sys Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`043ca000 fffff880`043d5000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01af3000 fffff880`01b05000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`012fd000 fffff880`01389000 mv91xx mv91xx.sys Fri Aug 27 10:49:22 2010 (4C778A22)
fffff880`01389000 fffff880`01391000 mvxxmm mvxxmm.sys Fri Aug 27 10:49:03 2010 (4C778A0F)
fffff880`01606000 fffff880`016f8000 ndis ndis.sys Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`061f0000 fffff880`061fc000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`06000000 fffff880`0602f000 ndiswan ndiswan.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`0676b000 fffff880`06780000 NDProxy NDProxy.SYS Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`04312000 fffff880`04321000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`0420b000 fffff880`04250000 netbt netbt.sys Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`016f8000 fffff880`01758000 NETIO NETIO.SYS Fri Apr 09 03:43:59 2010 (4BBE946F)
fffff880`01bb0000 fffff880`01bc1000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`043be000 fffff880`043ca000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02c12000 fffff800`031ee000 nt ntkrnlmp.exe Sat Jun 19 05:16:41 2010 (4C1C44A9)
fffff880`01456000 fffff880`015f9000 Ntfs Ntfs.sys Tue Jul 14 00:20:47 2009 (4A5BC14F)
fffff880`041f2000 fffff880`041fb000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`06753000 fffff880`0676b000 nusb3hub nusb3hub.sys Fri Apr 23 02:34:35 2010 (4BD0F92B)
fffff880`060ff000 fffff880`0612f000 nusb3xhc nusb3xhc.sys Fri Apr 23 02:34:36 2010 (4BD0F92C)
fffff880`042ec000 fffff880`04312000 pacer pacer.sys Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`00fb1000 fffff880`00fc6000 partmgr partmgr.sys Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00f71000 fffff880`00fa4000 pci pci.sys Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00fdb000 fffff880`00fe2000 pciide pciide.sys Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00fe2000 fffff880`00ff2000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0141a000 fffff880`0142b000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0b8ab000 fffff880`0b951000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`067a0000 fffff880`067dd000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c4e000 fffff880`00c62000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`061cc000 fffff880`061f0000 rasl2tp rasl2tp.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`0602f000 fffff880`0604a000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0604a000 fffff880`0606b000 raspptp raspptp.sys Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`0606b000 fffff880`06085000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`0436d000 fffff880`043be000 rdbss rdbss.sys Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`06085000 fffff880`06090000 rdpbus rdpbus.sys Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`0404a000 fffff880`04053000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`04053000 fffff880`0405c000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01b9c000 fffff880`01ba5000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01ab9000 fffff880`01af3000 rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`06637000 fffff880`0664f000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0bb7b000 fffff880`0bb81000 RTCore64 RTCore64.sys Wed May 25 07:39:12 2005 (42941D90)
fffff880`094b0000 fffff880`0970cd00 RTKVHD64 RTKVHD64.sys Tue Sep 07 12:17:23 2010 (4C861F43)
fffff880`00e21000 fffff880`00e50000 SCSIPORT SCSIPORT.SYS Tue Jul 14 01:01:04 2009 (4A5BCAC0)
fffff880`0b951000 fffff880`0b95c000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`0616f000 fffff880`0617b000 serenum serenum.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`04321000 fffff880`0433e000 serial serial.sys Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`017dd000 fffff880`017e5000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0bae2000 fffff880`0bb78000 srv srv.sys Fri Aug 27 04:38:00 2010 (4C773318)
fffff880`0b800000 fffff880`0b867000 srv2 srv2.sys Fri Aug 27 04:37:46 2010 (4C77330A)
fffff880`0b95c000 fffff880`0b989000 srvnet srvnet.sys Fri Aug 27 04:37:24 2010 (4C7732F4)
fffff880`0609f000 fffff880`060a0480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01803000 fffff880`01a00000 tcpip tcpip.sys Mon Jun 14 04:39:04 2010 (4C15A458)
fffff880`0b989000 fffff880`0b99b000 tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`01bdf000 fffff880`01bec000 TDI TDI.SYS Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`01bc1000 fffff880`01bdf000 tdx tdx.sys Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`04359000 fffff880`0436d000 termdd termdd.sys Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff960`00440000 fffff960`0044a000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`04558000 fffff880`0457e000 tunnel tunnel.sys Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`066e7000 fffff880`066f9000 umbus umbus.sys Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`09757000 fffff880`09771c00 usbaudio usbaudio.sys Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`0973a000 fffff880`09757000 usbccgp usbccgp.sys Tue Jul 14 01:06:45 2009 (4A5BCC15)
fffff880`0612f000 fffff880`06130f00 USBD USBD.SYS Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`0544f000 fffff880`05460000 usbehci usbehci.sys Sat Oct 24 05:27:33 2009 (4AE28235)
fffff880`066f9000 fffff880`06753000 usbhub usbhub.sys Sat Oct 24 05:28:24 2009 (4AE28268)
fffff880`060a9000 fffff880`060ff000 USBPORT USBPORT.SYS Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`00fa4000 fffff880`00fb1000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`04007000 fffff880`04015000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`04015000 fffff880`0403a000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`017cd000 fffff880`017dd000 vmstorfl vmstorfl.sys Tue Jul 14 00:42:54 2009 (4A5BC67E)
fffff880`00fc6000 fffff880`00fdb000 volmgr volmgr.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00d80000 fffff880`00ddc000 volmgrx volmgrx.sys Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`01197000 fffff880`011e3000 volsnap volsnap.sys Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`04250000 fffff880`042e3000 vsdatant vsdatant.sys Mon May 03 18:44:42 2010 (4BDF0B8A)
fffff880`0433e000 fffff880`04359000 wanarp wanarp.sys Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`0403a000 fffff880`0404a000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e54000 fffff880`00ef8000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ef8000 fffff880`00f07000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`042e3000 fffff880`042ec000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00080000 fffff960`00390000 win32k win32k.sys unavailable (00000000)
fffff880`06187000 fffff880`06190000 wmiacpi wmiacpi.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f5e000 fffff880`00f67000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`09466000 fffff880`09487000 WudfPf WudfPf.sys Tue Jul 14 01:05:37 2009 (4A5BCBD1)
fffff880`06606000 fffff880`06637000 WUDFRd WUDFRd.sys Tue Jul 14 01:06:06 2009 (4A5BCBEE)
cybercore
- Joined
- Jul 7, 2009
- Messages
- 15,641
Similar threads
- Article
- Replies
- 0
- Views
- 1K
- Article
- Replies
- 0
- Views
- 667
- Solved
- Replies
- 9
- Views
- 5K
- Solved
- Replies
- 5
- Views
- 4K
- Solved
- Replies
- 1
- Views
- 2K
