butterphobia
Hi everyone, I have been having a lot of issues with my computer for awhile now, all surrounding BSODs. I have noticed that whenever I have any flash thing open (Hulu, games), it BSODs really frequently. I don't really understand why it's happening... so hopefully you guys can help. I've attached that CPUZ stuff as well as minidumps I collected. Any advice would be greatly appreciated! Also i don't know if any other information is needed, so please ask :)
Thanks in advance!
Link RemovedLink RemovedLink Removed
When you wrote "The memory stick in slot #1 is set right", did you mean that it isn't set right?
The memory stick in slot #1 is set correctly indeed. If sticks in other slots are the same as the one you have in slot#1, then they are well matching.
Also, how does one go about updating drivers?
Manufacturers's support sites >> Drivers and Downloads. If this is a factory assembled pc, like Dell/ASUS/Aspire etc., then start with your PC manufacturer's site.
Broadcom.com - Downloads & Support
Download | Ricoh Support Europe
Uninstall Avast.
cybercore
The memory stick in slot #1 is set right.
120910-29296-01.dmp
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
DEFAULT_BUCKET_ID: NULL_CLASS_PTR_DEREFERENCE
MISALIGNED_IP:
nt!ExAcquireResourceExclusiveLite+3b
fffff800`02a9749b f6654c mul al,byte ptr [rbp+4Ch]
IMAGE_NAME: hardware
FAILURE_BUCKET_ID: X64_IP_MISALIGNED
Probably caused by : hardware ( dxgmms1!VidSchiWaitForSchedulerEvents+1ee )
dxgmms1.sys <-- DirectX driver
1. Uninstall Avast:
2. Replace that with MSE:
Link Removed due to 404 Error
3. Update drivers:
RICOH MMC
rixdpx64.sys Thu Jun 25 03:38:50 2009
Broadcom NetLink Gigabit Ethernet
k57nd60a.sys Sun Apr 26 07:23:05 2009
Intel GMA
igdkmd64.sys Wed Sep 23 15:22:57 2009
Broadcom 802.11 Network Adapter wireless
bcmwl664.sys Tue Jul 07 20:45:04 2009
4. If BSOD's persist after you follow the steps above, do some hardware testing:
Memtest86+ - Advanced Memory Diagnostic Tool 10 passes overnight
FurMark: VGA Stress Test, Graphics Card and GPU Stability Test, Burn-in Test, OpenGL Benchmark and GPU Temperature | oZone3D.Net
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\120910-29296-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02a1f000 PsLoadedModuleList = 0xfffff800`02c5ce50
Debug session time: Thu Dec  9 00:26:17.717 2010 (UTC - 5:00)
System Uptime: 1 days 11:00:09.861
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 1000007E, {ffffffffc0000005, fffff80002a9749b, fffff880058488a8, fffff88005848110}
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80002a9749b, The address that the exception occurred at
Arg3: fffff880058488a8, Exception Record Address
Arg4: fffff88005848110, Context Record Address
Debugging Details:
FAULTING_IP:
EXCEPTION_RECORD:  fffff880058488a8 -- (.exr 0xfffff880058488a8)
ExceptionAddress: fffff80002a9749b (nt!ExAcquireResourceExclusiveLite+0x000000000000003b)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: 000000000000004d
Attempt to read from address 000000000000004d
CONTEXT:  fffff88005848110 -- (.cxr 0xfffff88005848110)
rax=0000000000000001 rbx=fffffa80053734a8 rcx=fffffa80053734a8
rdx=0000000000187001 rsi=0000000000000002 rdi=fffff80002c09e80
rip=fffff80002a9749b rsp=fffff88005848ae0 rbp=0000000000000001
 r8=fffff80002a1f000  r9=0000000000000000 r10=fffffffffffffffe
r11=0000000000000246 r12=0000000000000000 r13=fffff88004346dc0
r14=0000000000000102 r15=0000000000000001
iopl=0         nv up ei pl nz na pe nc
cs=0010  ss=0000  ds=002b  es=002b  fs=0053  gs=002b             efl=00010202
nt!ExAcquireResourceExclusiveLite+0x3b:
fffff800`02a9749b f6654c          mul     al,byte ptr [rbp+4Ch] ss:00000000`0000004d=??
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  000000000000004d
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cc70e0
 000000000000004d
FOLLOWUP_IP:
fffff880`043472ae 413bde          cmp     ebx,r14d
BUGCHECK_STR:  0x7E
MISALIGNED_IP:
LAST_CONTROL_TRANSFER:  from fffff880043472ae to fffff80002a9749b
STACK_TEXT:
fffff880`05848ae0 fffff880`043472ae : fffffa80`00000002 00000000`00000001 00000000`00000002 00000000`00000000 : nt!ExAcquireResourceExclusiveLite+0x3b
fffff880`05848b50 fffff880`0431a2c6 : ffffffff`ff676980 fffffa80`05373010 00000000`00000000 00000000`00000000 : dxgmms1!VidSchiWaitForSchedulerEvents+0x1ee
fffff880`05848bf0 fffff880`04346e7a : 00000000`00000000 fffffa80`05d32d50 00000000`00000080 fffffa80`05373010 : dxgmms1!VidSchiScheduleCommandToRun+0x1da
fffff880`05848d00 fffff800`02d33c06 : 00000000`02017031 fffffa80`05344a10 fffffa80`036e5040 fffffa80`05344a10 : dxgmms1!VidSchiWorkerThread+0xba
fffff880`05848d40 fffff800`02a6dc26 : fffff880`009e7180 fffffa80`05344a10 fffff880`009f1f40 00000000`00000246 : nt!PspSystemThreadStartup+0x5a
fffff880`05848d80 00000000`00000000 : fffff880`05849000 fffff880`05843000 fffff880`05848690 00000000`00000000 : nt!KxStartSystemThread+0x16
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  dxgmms1!VidSchiWaitForSchedulerEvents+1ee
FOLLOWUP_NAME:  MachineOwner
DEBUG_FLR_IMAGE_TIMESTAMP:  0
STACK_COMMAND:  .cxr 0xfffff88005848110 ; kb
MODULE_NAME: hardware
Drivers:
fffff880`04b6f000 fffff880`04bad000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f7f000 fffff880`00fd6000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02c68000 fffff880`02cf2000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03a16000 fffff880`03a2c000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00ff4000 fffff880`00fff000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`01edd000 fffff880`01ee6000   aswFsBlk aswFsBlk.SYS Tue Sep 07 10:47:09 2010 (4C86506D)
fffff880`01ea3000 fffff880`01edd000   aswMonFlt aswMonFlt.sys Tue Sep 07 10:47:32 2010 (4C865084)
fffff880`02cf2000 fffff880`02cfc000   aswRdr   aswRdr.SYS   Tue Sep 07 10:47:47 2010 (4C865093)
fffff880`03b3c000 fffff880`03b5f000   aswSP    aswSP.SYS    Tue Sep 07 10:52:07 2010 (4C865197)
fffff880`0182b000 fffff880`0183b000   aswTdi   aswTdi.SYS   Tue Sep 07 10:52:27 2010 (4C8651AB)
fffff880`055ec000 fffff880`055f7000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00e99000 fffff880`00ea2000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00ea2000 fffff880`00ecc000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`00820000 fffff960`00881000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`00e5e000 fffff880`00e6a000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`04872000 fffff880`04b1a000   bcmwl664 bcmwl664.sys Tue Jul 07 20:45:04 2009 (4A53EC10)
fffff880`01966000 fffff880`0196d000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03b2b000 fffff880`03b3c000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0295f000 fffff880`0297d000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00790000 fffff960`007b7000   cdd      cdd.dll      unavailable (00000000)
fffff880`01933000 fffff880`0195d000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cd0000 fffff880`00d90000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`04cd1000 fffff880`04ce3000   circlass circlass.sys Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`018cb000 fffff880`018fb000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c72000 fffff880`00cd0000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04866000 fffff880`0486a500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`01000000 fffff880`01073000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`00e55000 fffff880`00e5e000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`03c00000 fffff880`03c10000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`04c76000 fffff880`04c84000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03a8a000 fffff880`03b0d000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`0540e000 fffff880`05420000   dc3d     dc3d.sys     Thu Jul 01 06:07:45 2010 (4C2C68F1)
fffff880`03b0d000 fffff880`03b2b000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02dc4000 fffff880`02dd3000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`018b5000 fffff880`018cb000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04c00000 fffff880`04c22000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`02df4000 fffff880`02e00000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`018fb000 fffff880`0190e000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0186a000 fffff880`01875000   dump_msahci dump_msahci.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0190e000 fffff880`0191a000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0421b000 fffff880`0430f000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`0430f000 fffff880`04355000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`05545000 fffff880`0557b000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`01139000 fffff880`0114d000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010ed000 fffff880`01139000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0187b000 fffff880`018b5000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01588000 fffff880`015d2000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`04200000 fffff880`0420d000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`02ffb000 fffff800`03044000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`043c9000 fffff880`043ed000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`04d64000 fffff880`04dc0000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`04c39000 fffff880`04c52000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`04c28000 fffff880`04c39000   hidir    hidir.sys    Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04c52000 fffff880`04c5a080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`01e72000 fffff880`01e80000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`02897000 fffff880`0295f000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01400000 fffff880`01409000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`03b85000 fffff880`03ba3000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`03c13000 fffff880`041f7fe0   igdkmd64 igdkmd64.sys Wed Sep 23 15:22:57 2009 (4ABA7591)
fffff880`03a00000 fffff880`03a16000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`03ba3000 fffff880`03bff000   itecir   itecir.sys   Wed Feb 24 03:59:35 2010 (4B84EA77)
fffff880`04b27000 fffff880`04b6f000   k57nd60a k57nd60a.sys Sun Apr 26 07:23:05 2009 (49F44419)
fffff880`043ed000 fffff880`043fc000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04c5b000 fffff880`04c69000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00ba7000 fffff800`00bb1000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04c8e000 fffff880`04cd1000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`0155d000 fffff880`01588000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`04c22000 fffff880`04c27200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`01f07000 fffff880`01f1c000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01e80000 fffff880`01ea3000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c1a000 fffff880`00c5e000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`0543c000 fffff880`0544a000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04857000 fffff880`04866000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04c69000 fffff880`04c76000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e7f000 fffff880`00e99000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0297d000 fffff880`02995000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`02995000 fffff880`029c2000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`02800000 fffff880`0284e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0284e000 fffff880`02871000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`00fe9000 fffff880`00ff4000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`019cb000 fffff880`019d6000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fdf000 fffff880`00fe9000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0114d000 fffff880`011ab000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02c5d000 fffff880`02c68000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`015ea000 fffff880`015fc000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0140b000 fffff880`014fd000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03a50000 fffff880`03a5c000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`01f6f000 fffff880`01f82000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`0183b000 fffff880`0186a000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04d4f000 fffff880`04d64000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d86000 fffff880`02d95000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02cfc000 fffff880`02d41000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`014fd000 fffff880`0155d000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`019d6000 fffff880`019e7000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02c51000 fffff880`02c5d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a1f000 fffff800`02ffb000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01245000 fffff880`013e8000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`0544a000 fffff880`05456000   NuidFltr NuidFltr.sys Tue Jun 29 04:54:32 2010 (4C29B4C8)
fffff880`0195d000 fffff880`01966000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`01f1c000 fffff880`01f6f000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02d4a000 fffff880`02d70000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00e40000 fffff880`00e55000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00dec000 fffff880`00dfc000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`034d4000 fffff880`0357a000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0542c000 fffff880`0543c000   point64  point64.sys  Tue Jun 29 04:54:31 2010 (4C29B4C7)
fffff880`04dc0000 fffff880`04dfd000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c5e000 fffff880`00c72000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`03a2c000 fffff880`03a50000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`03a5c000 fffff880`03a77000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`02dd3000 fffff880`02df4000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`011e5000 fffff880`011ff000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02c00000 fffff880`02c51000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`03a77000 fffff880`03a82000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`019b0000 fffff880`019b9000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019b9000 fffff880`019c2000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019c2000 fffff880`019cb000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`011ab000 fffff880`011e5000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`04bcd000 fffff880`04be3000   rimmpx64 rimmpx64.sys Thu Jun 25 04:04:18 2009 (4A432F82)
fffff880`04be3000 fffff880`04bfa000   rimspx64 rimspx64.sys Thu Jun 25 03:13:43 2009 (4A4323A7)
fffff880`04800000 fffff880`04857000   rixdpx64 rixdpx64.sys Thu Jun 25 03:38:50 2009 (4A43298A)
fffff880`01f82000 fffff880`01f9a000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04bad000 fffff880`04bcd000   sdbus    sdbus.sys    Fri Oct 09 22:41:20 2009 (4ACFF450)
fffff880`0357a000 fffff880`03585000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`015e2000 fffff880`015ea000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`054af000 fffff880`05545000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`03400000 fffff880`03467000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`03585000 fffff880`035b2000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`0486b000 fffff880`0486c480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01603000 fffff880`01800000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`035b2000 fffff880`035c4000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`0181e000 fffff880`0182b000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01800000 fffff880`0181e000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02db0000 fffff880`02dc4000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`005b0000 fffff960`005ba000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03b5f000 fffff880`03b85000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`04ce3000 fffff880`04cf5000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`010bf000 fffff880`010dc000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`04c84000 fffff880`04c85f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`043b8000 fffff880`043c9000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04cf5000 fffff880`04d4f000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04362000 fffff880`043b8000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`04355000 fffff880`04362000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`01e36000 fffff880`01e63200   usbvideo usbvideo.sys Wed Mar 03 23:40:57 2010 (4B8F39D9)
fffff880`00e33000 fffff880`00e40000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0196d000 fffff880`0197b000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`0197b000 fffff880`019a0000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`015d2000 fffff880`015e2000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00e6a000 fffff880`00e7f000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00d90000 fffff880`00dec000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01073000 fffff880`010bf000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`04b1a000 fffff880`04b27000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`02d70000 fffff880`02d86000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`02d95000 fffff880`02db0000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`019a0000 fffff880`019b0000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ecc000 fffff880`00f70000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f70000 fffff880`00f7f000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d41000 fffff880`02d4a000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00060000 fffff960`0036f000   win32k   win32k.sys   unavailable (00000000)
fffff880`0420d000 fffff880`04216000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fd6000 fffff880`00fdf000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`01ee6000 fffff880`01f07000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`055cd000 fffff880`055d9000   NuidFltr.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`05400000 fffff880`0540e000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`055d9000 fffff880`055e7000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`055bf000 fffff880`055cd000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0557b000 fffff880`05587000   NuidFltr.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`055b1000 fffff880`055bf000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`055a3000 fffff880`055b1000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`05595000 fffff880`055a3000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`05587000 fffff880`05595000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0549e000 fffff880`054ac000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`05420000 fffff880`0542c000   NuidFltr.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`05490000 fffff880`0549e000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`05482000 fffff880`05490000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`05474000 fffff880`05482000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`05466000 fffff880`05474000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`05458000 fffff880`05466000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0544a000 fffff880`05458000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0543c000 fffff880`0544a000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`055cf000 fffff880`055dd000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`05400000 fffff880`0540c000   usbprint.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`055dd000 fffff880`055e9000   NuidFltr.sys
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`055c1000 fffff880`055cf000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`055b3000 fffff880`055c1000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`055a5000 fffff880`055b3000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`05597000 fffff880`055a5000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`05589000 fffff880`05597000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0557b000 fffff880`05589000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0543c000 fffff880`054ad000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0557b000 fffff880`055ec000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01e64000 fffff880`01e72000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  00071000
butterphobia
Hi, thanks for the fast response! I will work through all of the suggestions. Just a few quick questions. When you wrote "The memory stick in slot #1 is set right", did you mean that it isn't set right? Also, how does one go about updating drivers? I tried checking the Ricoh website, but I did not manage to find what I was looking for (albeit, I wasn't sure what exactly it was that I was looking for).
Thanks for your help!
cybercore
Uninstall Avast.
butterphobia
I updated the drivers and uninstalled Avast, still getting the BSOD's so I will run the Memtest86+ tonight and post the results tomorrow.
As for the memory sticks, I believe this computer has 2 of them - is there any way to tell if the 2nd is set in correctly? They both came with the comp (Dell), so I assume they should be well-matching.
Thanks again for your help!
cybercore
Attach the screenshot of:
CPU-Z >> SPD tab >> Slot #2, #3, and #4.
butterphobia
There was only Slot #1 and 2 available. Computer has BSOD'd a couple times since i updated the drivers from Dell's website. Haven't gotten around to the memtest yet, still figuring out how to do it. Will post when done.
Link Removed - Invalid URL
butterphobia
So i ran the memtest and left it overnight, this morning i turned on my comp to find that it overheated and turned itself off... i'll try again during the day, but that does not sound like a good sign :/
cybercore
The sticks are set right and matching, DDR667 5-5-5-15.
One of them can be faulty, or sitting in a faulty slot sometimes.
Memtest doesn't overheat usually, unless the cooling is bad.
butterphobia
Huh maybe I have faulty fans then, because I tried running it twice and both times it said it "overheated" and shut down. @__@
