Srinathkn
Hello,
My frequest BSOD errors (followed by system reboot) point to drivers ks.sys, ntoskrnl.exe, usbaudio.sys and stdriver64.sys. --- to my knowledge.
As for as usbaudio.sys is concerned, I am using rapoo Wifi wireless head phones and so RF USB will be plugged. I cannot remove this.
Here is the summary of the core dumps zipped in attachment:
Dump File : 090812-48906-01.dmp
Crash Time : 9/8/2012 11:37:16 PM
Bug Check String : BAD_POOL_HEADER
Bug Check Code : 0x00000019
Parameter 1 : 00000000`00000022
Parameter 2 : 00000000`00000000
Parameter 3 : 00000000`00000000
Parameter 4 : 00000000`00000000
Caused By Driver : ks.sys
Caused By Address : ks.sys+3055f
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+7f1c0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\090812-48906-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7601
Dump File Size : 278,528
Dump File : 090612-30357-01.dmp
Crash Time : 9/6/2012 4:41:41 PM
Bug Check String : PROCESS_HAS_LOCKED_PAGES
Bug Check Code : 0x00000076
Parameter 1 : 00000000`00000000
Parameter 2 : fffffa80`08881b30
Parameter 3 : 00000000`00000005
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+7f1c0
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7601.17835 (win7sp1_gdr.120503-2030)
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\090612-30357-01.dmp
Major Version : 15
Dump File Size : 319,112
Dump File : 090512-51651-01.dmp
Crash Time : 9/5/2012 9:07:05 AM
Bug Check String : SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x1000007e
Parameter 1 : ffffffff`c0000005
Parameter 2 : fffff880`063c0be8
Parameter 3 : fffff880`079f9928
Parameter 4 : fffff880`079f9180
Caused By Driver : usbaudio.sys
Caused By Address : usbaudio.sys+137a3
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : stdriver64.sys+1be8
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\090512-51651-01.dmp
Major Version : 15
Dump File : 090112-31293-01.dmp
Crash Time : 9/1/2012 2:27:37 PM
Bug Check String : BAD_POOL_CALLER
Bug Check Code : 0x000000c2
Parameter 1 : 00000000`00000007
Parameter 2 : 00000000`0000109b
Parameter 3 : 00000000`0402000b
Parameter 4 : fffffa80`087a0790
Caused By Driver : stdriver64.sys
Caused By Address : stdriver64.sys+2674
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\090112-31293-01.dmp
Major Version : 15
Dump File : 082812-35334-01.dmp
Crash Time : 8/28/2012 2:44:10 AM
Bug Check String : SYSTEM_SERVICE_EXCEPTION
Bug Check Code : 0x0000003b
Parameter 1 : 00000000`c0000005
Parameter 2 : fffff800`03308ec8
Parameter 3 : fffff880`08256390
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\082812-35334-01.dmp
Major Version : 15
Can you please suggest some work arounds for this please....
Thanks,
("Lord, let there be no BSOD crash reboot today")
John,
These are the changes made:
Logitech driver was installed from the manufacturers of Logitech web cam towards having new LVUSBS64.sys and LV561V64.SYS. The orphan driver RimSerial_AMD64.sys did not get uninstalled when the application associated was uninslatted. So, I manually removed the driver.
Difficult to remove orphan drivers from machine.
With all this in place, since the day the logitech driver was installed i.e., 4 days ago, NO BSOD ERROR IS SEEN. I consider that your solution has worked out. Thank you.
I think MS should build a robust OS which will handle drivers by itself for all devices (any make) intelligently without needing user to know what is happening!. That area is very weak. at the moment.
Thank you...
usasma
Fantastic Member
Download new SoundTap drivers
Un-install the current SoundTap drivers
Install the new SoundTap drivers
Monitor for further BSOD's
If that doesn't fix it, then I'd have to wonder about a hardware problem with your USB equipment.
LVUSBS64.sys Thu Oct 11 21:39:40 2007 (470ED05C)
Logitech Camera driver
LV561V64.SYS Thu Oct 11 21:42:44 2007 (470ED114)
Logitech Webcam driver
RimSerial_AMD64.sys Mon Nov 24 12:01:01 2008 (492ADDCD)
Virtual Serial Port driver for Blackberry
hardlock.sys Mon Feb 2 10:34:08 2009 (49871270)
Hardlock Device Driver by Aladdin KnowledgeSystems
aksfridge.sys Wed Aug 19 09:38:43 2009 (4A8C0063)
AksFridge driver (Aladdin security products)
HECIx64.sys Thu Sep 17 15:54:16 2009 (4AB293E8)
Intel Management Engine Interface
aksdf.sys Fri Sep 18 09:04:24 2009 (4AB38558)
Data Filter Driver by Aladdin Knowledge Systems
dvmio.sys Tue Nov 10 23:38:32 2009 (4AFA3FC8)
HP QuickWeb - instructions here: Link Removed - Invalid URL
Analysis:
[font=lucida console]**************************Sat Sep  8 23:35:37.740 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090812-48906-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]1 days 12:24:49.969[/B]
BugCheck Code: [B]BugCheck 19, {22, 0, 0, 0}[/B]
*** WARNING: Unable to verify timestamp for stdriver64.sys
*** ERROR: Module load completed but symbols could not be loaded for stdriver64.sys
*** WARNING: Unable to verify checksum for win32k.sys
Probably caused by :[B]stdriver64.sys ( stdriver64+2669 )[/B]
BugCheck Info: [B]BAD_POOL_HEADER (19)[/B]
BUGCHECK_STR:  0x19_22
PROCESS_NAME: [B]stacsv64.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x19_22_stdriver64+2669[/B]
CPUID:        "Intel(R) Core(TM) i3 CPU       M 350  @ 2.27GHz"
MaxSpeed:     2270
CurrentSpeed: [B]2261[/B]
  BIOS Version                  F.25
  BIOS Release Date             01/12/2011
  Manufacturer                  Hewlett-Packard
  Product Name                  HP Pavilion dv6 Notebook PC
**************************Thu Sep  6 16:40:02.148 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090612-30357-01.dmp]
System Uptime:[B]0 days 8:16:06.615[/B]
BugCheck Code: [B]BugCheck 76, {0, fffffa8008881b30, 5, 0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::NNGAKEGL::`string'+18026 )[/B]
BugCheck Info: [B]PROCESS_HAS_LOCKED_PAGES (76)[/B]
PROCESS_NAME: [B]audiodg.exe[/B]
DEFAULT_BUCKET_ID:  DRIVER_FAULT_0x76
BUGCHECK_STR:  0x76
FAILURE_BUCKET_ID: [B]X64_0x76_audiodg.exe_nt!_??_::NNGAKEGL::_string_+18026[/B]
MaxSpeed:     2270
  BIOS Version                  F.25
**************************Wed Sep  5 09:05:36.262 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090512-51651-01.dmp]
System Uptime:[B]0 days 8:58:14.729[/B]
BugCheck Code: [B]BugCheck 1000007E, {ffffffffc0000005, fffff880063c0be8, fffff880079f9928, fffff880079f9180}[/B]
*** ERROR: Module load completed but symbols could not be loaded for usbaudio.sys
Probably caused by :[B]stdriver64.sys ( stdriver64+1be8 )[/B]
BugCheck Info: [B]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/B]
PROCESS_NAME: [B]System[/B]
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID: [B]X64_0x7E_stdriver64+1be8[/B]
MaxSpeed:     2270
  BIOS Version                  F.25
**************************Sat Sep  1 14:26:15.161 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090112-31293-01.dmp]
System Uptime:[B]0 days 1:36:02.629[/B]
BugCheck Code: [B]BugCheck C2, {7, 109b, 402000b, fffffa80087a0790}[/B]
Probably caused by :[B]stdriver64.sys ( stdriver64+2674 )[/B]
BugCheck Info: [B]BAD_POOL_CALLER (c2)[/B]
BUGCHECK_STR:  0xc2_7_NPag
FAILURE_BUCKET_ID: [B]X64_0xc2_7_NPag_stdriver64+2674[/B]
MaxSpeed:     2270
  BIOS Version                  F.25
**************************Tue Aug 28 02:42:25.866 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082812-35334-01.dmp]
System Uptime:[B]0 days 0:39:26.959[/B]
BugCheck Code: [B]BugCheck 3B, {c0000005, fffff80003308ec8, fffff88008256390, 0}[/B]
Probably caused by :[B]stdriver64.sys ( stdriver64+2388 )[/B]
BugCheck Info: [B]SYSTEM_SERVICE_EXCEPTION (3b)[/B]
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]X64_0x3B_stdriver64+2388[/B]
MaxSpeed:     2270
  BIOS Version                  F.25
[/font]
3rd Party Drivers:
Any drivers in red should be updated.
[B]LVUSBS64.sys                Thu Oct 11 21:39:40 2007 (470ED05C)[/B]
[B]RimSerial_AMD64.sys         Mon Nov 24 12:01:01 2008 (492ADDCD)[/B]
[B]hardlock.sys                Mon Feb  2 10:34:08 2009 (49871270)[/B]
GEARAspiWDM.sys             Mon May 18 08:17:04 2009 (4A1151C0)
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
IntcDAud.sys                Wed Feb  3 08:38:31 2010 (4B697C57)
Impcd.sys                   Wed Feb 10 18:01:59 2010 (4B733AE7)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
iaStor.sys                  Tue Apr 13 12:44:16 2010 (4BC49F60)
Accelerometer.sys           Fri Jul 16 11:02:38 2010 (4C40748E)
hpdskflt.sys                Fri Jul 16 11:02:38 2010 (4C40748E)
stwrt64.sys                 Thu Jul 22 03:25:34 2010 (4C47F26E)
igdkmd64.sys                Wed Jul 28 17:10:36 2010 (4C509CCC)
NETwNs64.sys                Mon Oct 18 05:21:28 2010 (4CBC1198)
Ironx64.SYS                 Fri Nov 12 18:06:50 2010 (4CDDC88A)
SYMDS64.SYS                 Tue Dec  7 19:16:58 2010 (4CFECE7A)
stdriver64.sys              Sun Dec 12 22:30:59 2010 (4D059373)
SYMEFA64.SYS                Sun Mar 13 23:20:58 2011 (4D7D899A)
SYMEVENT64x86.SYS           Thu Mar 24 19:02:36 2011 (4D8BCD8C)
SRTSP64.SYS                 Tue Mar 29 22:46:12 2011 (4D929974)
SRTSPX64.SYS                Tue Mar 29 22:46:18 2011 (4D92997A)
SYMNETS.SYS                 Tue Apr 19 18:33:31 2011 (4DAE0DBB)
Sftvollh.sys                Fri Sep 30 12:42:46 2011 (4E85F186)
Sftplaylh.sys               Fri Sep 30 12:43:05 2011 (4E85F199)
Sftfslh.sys                 Fri Sep 30 12:43:06 2011 (4E85F19A)
Sftredirlh.sys              Fri Sep 30 12:43:14 2011 (4E85F1A2)
SynTP.sys                   Thu Oct 13 22:34:52 2011 (4E979FCC)
EraserUtilRebootDrv.sys     Tue Jul 31 19:36:50 2012 (50186C12)
eeCtrl64.sys                Tue Jul 31 19:36:51 2012 (50186C13)
EX64.SYS                    Tue Aug  7 04:43:08 2012 (5020D51C)
ENG64.SYS                   Tue Aug  7 04:45:01 2012 (5020D58D)
IDSvia64.sys                Tue Aug 28 22:48:40 2012 (503D8308)
BHDrvx64.sys                Tue Aug 28 23:12:41 2012 (503D88A9)
[B]LV561V64.SYS                Thu Oct 11 21:42:44 2007 (470ED114)[/B]
Rt64win7.sys                Wed Jun 23 05:10:45 2010 (4C21CF95)
BHDrvx64.sys                Wed May 16 22:16:36 2012 (4FB45F84)
IDSvia64.sys                Wed Aug  8 14:49:41 2012 (5022B4C5)
BHDrvx64.sys                Thu Aug  9 03:14:17 2012 (50236349)
[/font]
Srinathkn
Thanks a lot for the answers!.
I was not able to get latest drivers for the following: hardlock.sys, aksfridge.sys, HECIx64.sys, aksdf.sys, dvmio.sys. I am still working on these and I will keep you posted of my test results.
Thanks again,
Srinath
usasma
Fantastic Member
The key here is if the BSOD's stop. If you haven't updated those drivers - and the BSOD's stop anyway - then those drivers aren't the problem (and updating them becomes less urgent).
You may not be able to find updated drivers for dvmio.sys (it appears to me that HP doesn't update their drivers unless they see a need to do it). If so, either un-install their program - or just leave it and we'll see what happens with the next BSOD.
As for the others, un-install the Aladdin and Hardlock programs temporarily to see if that helps.
Srinathkn
John,
Thank you always,
Srinath
usasma
Fantastic Member
MS has put that in place - but the manufacturer's of the 3rd party drivers don't have to comply with that specification.
And if MS was to require it, then you wouldn't have the wide choice of software for Windows that you have now.
Good luck to you!
