The user reports that only their primary Planar touchscreen monitor responds to touch, while the secondary does not, regardless of which monitor is set as primary—a change from behavior in a previous Windows Consumer Preview where both responded to touch. The responses suggest that this is not normal behavior and recommend troubleshooting steps including checking touch settings, updating drivers, calibrating touchscreens, reviewing display and software configurations, ensuring Windows is up to date, and considering compatibility issues. Overall, the thread highlights user frustration with the change in touchscreen responsiveness and provides guidance on how to attempt to restore functionality to both monitors.
Cosmonium
Hello. I have two Planar touchscreen monitors. Only the primary monitor responds to touch. The secondary monitor only responds to the mouse. If I switch which monitor is primary, that monitor responds to touch and the other one will only respond to the mouse. So, the issue is that only the monitor designated as primary will respond to touch, while the other will only respond to the mouse regardless of which monitor I choose as the primary. On the Consumer Preview, both of these monitors responded to touch. What has changed? Is there any way that both monitors will respond to touch as they did in the Consumer Preview? Thank you!
It sounds like you are encountering an issue with the touchscreen functionality on your Planar monitors in Windows. The behavior you described where only the primary monitor responds to touch irrespective of its position is not the expected behavior for a multi-monitor setup. To troubleshoot and potentially resolve this issue, you can try the following steps: 1. Check Windows Touch Settings: - Open the Windows Settings app. - Go to "Devices" and select "Touchpad" from the left menu. - Ensure that the touch settings for both monitors are configured correctly. 2. Update Drivers: - Ensure that you have the latest drivers for your monitors installed. You can check the manufacturer's website for driver updates. 3. Calibrate...
It sounds like you are encountering an issue with the touchscreen functionality on your Planar monitors in Windows. The behavior you described where only the primary monitor responds to touch irrespective of its position is not the expected behavior for a multi-monitor setup. To troubleshoot and potentially resolve this issue, you can try the following steps: 1. Check Windows Touch Settings: - Open the Windows Settings app. - Go to "Devices" and select "Touchpad" from the left menu. - Ensure that the touch settings for both monitors are configured correctly. 2. Update Drivers: - Ensure that you have the latest drivers for your monitors installed. You can check the manufacturer's website for driver updates. 3. Calibrate Touchscreen: - In Windows, you can calibrate the touchscreen to improve its accuracy and responsiveness. This might help in resolving the issue. 4. Check Display Settings: - Go to "Display Settings" in Windows. - Check the settings for each monitor, especially the touch settings. 5. Third-Party Software Conflict: - If you have any third-party software related to touch or display management, try disabling it temporarily to see if it affects the touchscreen behavior. 6. Windows Updates: - Ensure that your Windows operating system is up to date. Sometimes Windows updates can bring fixes for such issues. 7. Revert to Previous Build: - If the issue started after a specific Windows update, consider rolling back to a previous build where the touchscreen functionality worked as expected, if possible. If you have already checked these steps and the issue persists, you may need to further investigate compatibility issues between your hardware setup and the current version of Windows. In some cases, reaching out to the manufacturer for support or waiting for Windows updates that address such compatibility issues might be necessary. By following these steps, you can troubleshoot the touchscreen behavior on your Planar monitors and potentially restore the touch functionality to both monitors as it was in the Consumer Preview version.
