krisacharia
Laptop Toshiba Satellite Pro A300.CPU Intel Core3 Duo P8400. Wirless Lan Intel(R)WIFI Link 5100.
When I enable bluetooth I get the following caution:
"Bluetooth and Wireless Lan devices operate within the same radio frequency range and may interfere with one another. You may experience less optimal netwrk performance or even loose connection. Alwats cease either your bluetooth or wireless lan operation."
Any help and advice please.
Thanks
Along with Saltgrass excellent advice....the only time you would need to enable the blue tooth feature is when using a bluetooth device...other wise it doesn't need to be enabled.
Saltgrass
Although the message would seem to be proper, are you seeing a problem with your network?
Are you using the Bluetooth Network Adapter, or just some Bluetooth devices?
I tried to run a Bluetooth mouse and keyboard on my system, but the response from the Bluetooth devices was insufficient for their use.
Jimbo22
krisacharia
Highly useful and problem solving advice. Thank you.
