- Joined
- Feb 5, 2009
- Messages
- 1,707
Since I've taken up gaming I've been paying particular attention to CPU core percentages and fan speed. I have a Rainmeter Widget that shows bar graphs for the individual cores. I've seen it peg all four cores at 100% for almost 10 minutes during game installation. The fans never came on. I used to hear the fans and feel heat coming from the air ports on the back. But lately they're not coming on at all. I tried out a hardware info widget and that showed the core temps to never go over about 45° Celsius. Also it never feels over just slightly warm on the outside. There's a conflict between the Dell system monitors and HWInfo that caused horrible sounding noises from the speakers so I removed it. I've tried to find a way to just turn on the fans manually but haven't found one. I can't find anything in the BIOS about it. Dell Support says my drivers are all up to date.
A few days back I tried to roll back the latest Windows Insider test version and it broke my system. I downloaded and burned a Windows disk and did a clean install. That seemed to go well. I'm not going back to the Windows Insider Program.
The back comes off all in one piece and is held on with just one screw. When I remove it I never see a hint of dust.
The first time SFC said there were violations that couldn't be fixed. I ran the DISM Restore Health thing. The second time SFC said it found violations and fixed them. The third time it came up clean.
Once in a while it gets a little balky when I first try to go online. Task manager says it's a DNS thing when it happens and it clears up pretty fast. It never gives me reason to think heat is causing problems. Once in a while Windows Update takes over and it runs a little weird. Then it comes up saying a reboot is required to apply updates. That's when I realize W/U has been running.
It all seems pretty normal to me except the fans don't come on anymore.
It's an Inspiron 15 7559. I did do the SSD upgrade and doubled the RAM. It handles any graphic challenges I throw at it with ease. I'm very happy with it.
