The forum discussion centers on retrieving data from an old, physically damaged SATA hard drive. The original poster asks about alternative methods due to a broken connector, with suggestions including using a USB-to-SATA adapter and seeking professional data recovery services. Participants generally advise caution, recommending professional help for valuable data and noting that minor physical fixes might restore access, but overall, the tone is cautious and practical.
Pie King
hi I have a very old Hard Drive the small SATA thing broken so I can't connect a wire to it and now I can't use it any more I need to get some data of it is there any other method of using the hard drive
helpifIcan
Fantastic Member
Your only chance of getting the data off is to find a drive of the same make & model swap over the controller board and hope for the best.
Pauli
Fantastic Member
If possible, and the data is valuable, I would not to try to experiment anything, but to take it to some service. Don't know what the cost will be, but it should be safe and, besides, cables don't come free either. Smaller businesses often charge reasonably, and to have a customer relation is never bad.
Best of all.
patcooke
Microsoft MVP
Microsoft MVP
If you are unsure of handling it then I'd follow Pauli's advice.
helpifIcan
Fantastic Member
Most places charge a large fee to recover data, it would have to be very valuable data. Most of these companies only deal with commercial companies that have had a catastrophic failure.
patcooke
Microsoft MVP
Microsoft MVP
Depending on the extent of the physical damage to the pin it is more about being able to make the physical connection. There is no suggestion that there is damage to the data storage so is unlikely to involve expensive data recovery. I personally would attempt to make the connection between the sata connections on the drive to a usb interface. I've used paper clips to bridge damaged data connections before today!
Pauli
Fantastic Member
What I referred to was not specialist companies doing data recovery but plain IT-retailers with service. If it is a plain physical damage of the contact, any engineer with self respect should be able to fix it, and it shouldn't cost too much. But this is merely my opinion, can't excel with expertise.
The disk may not be fixed fully functional, but only to an extent where it will make contact = data can be transferred.
