strouzy
I am really satisfied with Windows 7- I installed it on my ASUS pro31jc Notebook and it runs almost perfect. I only have isues with my Laptop (not with Windows 7) and my Problem is following:
My Laptop Fan is too loud, maybe it is because its too old. Maybe my Fan is working as it should and i never Recognized the sound because i was HEaring Music or was playing Games all the Time.
I used the ASUS tool "Powe 4 Gear" the XP version worked perfectly under Windows 7 and i got a nice result. Satisfaction is the death of desire ... so i decided that my Notebook still is too loud and installed NHC2.0 (the Notebook Hardware Control)
In this nice Programm you have the Option to set the CPU speed at a level of your Choice - i just tried to set the CPU Speed at 50% max. so it wouldn't heat up and i could decrease the fan speed to a level where the CPU temperature is at a Minimum with the lowest Fan activity needed.
After setting my CPU to 50% Speed i noticed that it still jumps to 100% from time to time for almost a second or so. Is a controller broken ? or is it normal
It seems like you are facing some issues with the fan noise on your ASUS pro31jc Notebook running Windows 7 and trying to control the CPU speed to manage the fan activity effectively. Here are some insights and suggestions to address your concerns: 1. Fan Noise and CPU Speed Issues: - Fan Noise: Loud fan noise can be due to various reasons such as dust accumulation, a faulty fan, or the system working harder than it should be. - CPU Speed: Setting the CPU speed lower can help reduce heat generation and fan speed, but it might not completely eliminate the occasional spikes to 100% speed. 2. Possible Explanations for CPU Spikes: - Normal Operation: It is not uncommon for the CPU to briefly peak to 100% speed...
It seems like you are facing some issues with the fan noise on your ASUS pro31jc Notebook running Windows 7 and trying to control the CPU speed to manage the fan activity effectively. Here are some insights and suggestions to address your concerns: 1. Fan Noise and CPU Speed Issues: - Fan Noise: Loud fan noise can be due to various reasons such as dust accumulation, a faulty fan, or the system working harder than it should be. - CPU Speed: Setting the CPU speed lower can help reduce heat generation and fan speed, but it might not completely eliminate the occasional spikes to 100% speed. 2. Possible Explanations for CPU Spikes: - Normal Operation: It is not uncommon for the CPU to briefly peak to 100% speed, especially when handling demanding tasks or sudden load increases. - Process Intensity: Background processes or system tasks can also trigger these spikes briefly. 3. Troubleshooting Steps: - Clean the Fan: Ensure that your laptop's fan and vents are clean from dust. Dust can hinder effective cooling, leading to increased fan noise. - Update Drivers: Make sure all your drivers are up to date, including those related to the fan control and power management. - Temperature Monitoring: Monitor your CPU temperature to ensure it stays within safe limits even during the spikes. 4. Regarding Hardware Control Programs: - Notebook Hardware Control (NHC): Check the settings in NHC 2.0 to ensure that the CPU speed configuration is applied correctly and that there are no conflicts with other software. - ASUS Power4Gear: You mentioned using Power4Gear successfully. It's a good idea to check if it has any control over the fan settings as well. 5. Controller Failure: - Hardware Inspection: If the issue persists, there might be a need to inspect the hardware, especially the fan and its controller, to rule out any physical defects. 6. Additional Tips: - Balance Performance and Fan Noise: Finding the right balance between performance and fan noise is essential. Adjusting power settings and managing background processes can help. - Regular Maintenance: Periodic cleaning and maintenance of the laptop's cooling system can significantly reduce fan noise and prevent overheating issues. By following these steps and keeping an eye on the laptop's performance and temperatures, you can effectively manage fan noise and ensure optimal operation of your ASUS Notebook running Windows 7.
