This firmware update tool provides the latest firmware for the following Intel SSDs in all capacities:
- Intel® X25-M/X18-M SATA SSD on 50nm (black case) - updates to FW version 8820
- Intel® X25-E SATA SSD on 50nm (black case) - updates to FW version 8850
- Intel® X25-M/X18-M SATA SSD on 34nm (silver case) - updates to FW version 02HD
This firmware will enable your SSD to deliver the best performance in your PC. Use this update tool to get the latest production firmware.
Before initiating the Intel SSD firmware update, be sure to read and precisely follow the instructions included in the Firmware Update Guideline, Readme and Release Notes. You may wish to print these instructions for easy reference.
The Readme.txt file includes the SSD firmware update instructions.
The SSD Firmware Update Guideline is available
here .
Link Removed - Invalid URL
It seems like you're looking for information on updating the firmware for Intel SSDs. Here is a breakdown of the firmware updates for specific Intel SSD models:
  • Intel® X25-M/X18-M SATA SSD on 50nm (black case): The firmware update for this SSD model upgrades it to FW version 8820.
  • Intel® X25-E SATA SSD on 50nm (black case): The firmware update for this SSD model enhances it to FW version 8850.
  • Intel® X25-M/X18-M SATA SSD on 34nm (silver case): The firmware update for this SSD model brings it to FW version 02HD. Firmware updates are crucial for improving the performance and functionality of your SSD. It's important to carefully follow the instructions provided in the Firmware Update Guideline, Readme, and...
  • Intel® X25-M/X18-M SATA SSD on 34nm (silver case): The firmware update for this SSD model brings it to FW version 02HD. Firmware updates are crucial for improving the performance and functionality of your SSD. It's important to carefully follow the instructions provided in the Firmware Update Guideline, Readme, and Release Notes before proceeding with the update. Printing these instructions for easy reference is a good idea. You mentioned a Readme.txt file that contains the SSD firmware update instructions, which will guide you through the update process. For further details and guidelines, you can refer to the http://www.intel.com/support/ssdc/hpssd/sb/CS-031009.htm. If you have any specific questions or need further assistance with the firmware update process, feel free to ask!
