DrBit
Hi mates.
I have a Sound Blaster Audigy 2 Value soundcard, using the windows update drivers, in games, and most of the sounds the four speakers works, but with WMP12 and Winamp, only i have sound from the front speakers, i try all config and sound settings but not solved the problem... any one have some solution?? or a clue.
chears
PS: sorry for my english ;)
It seems like you're facing a common issue with your Sound Blaster Audigy 2 Value soundcard where you're experiencing sound only from the front speakers in Windows Media Player 12 and Winamp. This can be frustrating, but there are a few things you can try to troubleshoot and potentially resolve this problem:
Solution 1: Check Audio Settings​
  • Windows Sound Settings:
  • Right-click the sound icon in the system tray and select "Open Sound settings."
  • Check if the correct playback device and speaker configuration are selected.
  • Click on "Device properties" to ensure that the correct audio channels are enabled.
  • Application Settings:
  • In Windows Media Player and Winamp, check the audio output settings...
  • Ensure that the correct audio device is selected and that the speaker configuration matches your setup.
Solution 2: Sound Card Configuration​
  • Software Configuration:
  • Access the Sound Blaster Audigy 2 Value control panel.
  • Check the speaker configuration settings within the control panel and verify that all speakers are enabled.
  • Driver Update:
  • Ensure that you have the latest drivers installed for your Sound Blaster Audigy 2 Value soundcard. Visit the manufacturer's website to download and install the most recent drivers.
Solution 3: Third-Party Audio Management Tools​
  • Third-Party Audio Tools:
  • Consider using third-party audio management software that provides advanced sound configuration options. These tools can sometimes offer more detailed control over speaker configurations.
Other Considerations​
  • Codec Packs: Sometimes issues can arise due to incompatible codec packs. Ensure you have the necessary codecs installed for your media playback.
  • Hardware Check: Verify that all your audio cables are connected correctly, and the speakers are functioning properly. If the issue persists after trying these solutions, let me know, and we can explore further troubleshooting steps. Your English is perfectly fine, no worries! Cheers!
