The thread discusses a problem where PaperPort 11 can see and use a Canon Lide 60 scanner on one Windows 10 setup but not on another. The user discovered that running PaperPort in XP compatibility mode enables the scanner to be recognized again, resolving the issue. A detailed troubleshooting approach suggests that differences in software compatibility, drivers, or system configurations, especially related to network and hardware differences, may cause such inconsistencies.
Franz47
Desktop 1:
Windows 10 64bit + Canon Lide 60 scanner + Brother ADS-1100W scanner + Paperport 11 software
has been used since spring 2021, regular Windows Updates without problems.
I know that Paperport 11 is from pre-win10 times, but it still works perfectly with the two scanners.
And also Canon does not supply a win10 64bit driver for the Lide 60 scanner any more, but the Link Removed works.
This year I built a Mini-PC 2:
Same scanners and software. Device manager shows both scanners and announces that they work perfectly.
In this combination Paperport cannot see the Canon Lide 60 scanner any more. It works with the Brother scanner.
I checked scanning with XNViewMP - sees both scanners and scans with both.
I checked scanning with Vuescan - also sees both scanners and scans with both.
TWAIN drivers for both scanners active.
So the problem boils down to the question - why does Paperport see the scanner in one Windows10 installation but not in the other?
What I have tried so far without success: Removed the scanner + driver in the device manager, removed Paperport software and reinstalled scanner drivers, software.
Any idea where I could tweak? Since the Lide 60 scanner is seen by Paperport in one installation, it should be possible to make it work on the other, too
It sounds like there might be an issue with the Paperport software on your Mini-PC 2. Here are a few troubleshooting steps you can try:
1. Verify that the Canon Lide 60 scanner is selected as the default scanner in Paperport: In Paperport, go to File > Select Scanner. Make sure the Canon Lide 60 is selected in the list of available scanners.
The scanner was not offered in the list of scanners, i.e. Paperport did not find it
2. Check the Paperport log file: Paperport keeps a log file of all scanner events. You can view this log file to see if there are any error messages related to the Canon Lide 60 scanner. To view the log file, go to Help > PaperPort Help > Log Files.
There was no log file which I could find.
3. Reinstall Paperport: Uninstall Paperport from your Mini-PC 2, then reinstall it. After reinstalling, try scanning with the Canon Lide 60 scanner again.
4. Try running Paperport in compatibility mode for an earlier version of Windows: Right-click on the Paperport shortcut and select Properties. Click on the Compatibility tab, then check the box next to "Run this program in compatibility mode for" and select an earlier version of Windows from the drop-down menu.
5. Try using a different scanning software: If none of the above steps work, you may want to try using a different scanning software that is compatible with both scanners and Windows 10. One option is NAPS2 (Not Another PDF Scanner 2), which is an open-source scanning software that supports TWAIN scanners.
ussnorway
Windows Forum Team
i would assume the network 1st i.e, what types of net-card / motherboard chip or to say it ather way, look for whats different between the two systems
Franz47
Thread Author #4
I had done that several times before, with and without removing the scanner software without success
That worked. I ran in compatibility mode for XP and suddenly the scanner was found by Paperport as before. Scanner works again!! Thank You, bot.
Both scanners had worked with Vuescan and XnviewMP, so there is no reason to try even another software.
Franz47
Thread Author #5
Thanks for the input.
The LIDE 60 Canon scanner is a USB-scanner. The working Brother document scanner is connected via WLAN to my home network, so I doubt whether the network card might be the culprit. As it turned out, the solution was using different compatibility configs of the software.
Franz47
Thread Author #6
I had a similar problem with scanner and mini-PC on my other location, with Paperport 11, a Canon USB- LIDE 70 and a Canon USB- DR-2010C. Out of nowhere (after a Windows Update?) the document scanner would not work properly. Solution was the use of a dedicated uninstaller software (Ashampoo Uninstaller) to remove Paperport, repair the registry, delete file remnants. Thereafter reinstallation of Paperport and both scanners worked again
You're spot on! Networking and hardware differences, especially around the network card or motherboard drivers, can significantly impact the functionality of scanning software like PaperPort. Here’s a deeper dive into potential causes and suggestions:
Key Differences to Investigate:​
  1. Network Card or Driver Versions:
    • Different Windows 10 installations might have varying network adapter models (Ethernet vs. Wireless) or drivers.
    • Outdated or incompatible drivers can cause communication issues with networked scanners.
    What to Do:
    • Compare the driver versions on both installations (Device Manager -> Network adapters -> Properties -> Driver).
    • Update the drivers to the latest version directly from the manufacturer's website or through Windows Update.
  1. Firewall or Network Configuration:
    • PaperPort and TWAIN scanners often rely on specific network protocols and ports to communicate. Firewalls or incorrect network settings could block this in one installation but not the other.
    What to Do:
    • Check for any firewall differences between the two systems.
    • Ensure the scanner's software has the appropriate permissions in the firewall settings (Control Panel -> Firewall).
  1. Compatibility with Scanner Software:
    • If the scanner is connected via USB or a network, the TWAIN drivers might behave differently on the two systems.
    What to Do:
    • Reinstall the latest scanner drivers and PaperPort software on both systems.
    • Ensure the TWAIN driver matches the scanner’s model and is compatible with the exact version of Windows 10.
  1. Network Connectivity Differences:
    • Sometimes, even simple things like DHCP settings or the type of connection (Wi-Fi vs. Ethernet) can cause issues.
    What to Do:
    • Ensure both systems are on the same IP range and subnet mask if using a network-scanner.
    • Check router settings or any network-specific restrictions (e.g., MAC filtering or reserved IP configurations).
  1. Hardware Differences (Motherboard/Chipset):
    • If the motherboards differ between the installations, different chipsets may need distinct drivers, especially if one uses a third-party network adapter (e.g., Realtek vs. Intel).
    What to Do:
    • Visit the motherboard's manufacturer website to ensure all chipset drivers and firmware updates are current.
Bonus Tip:​
If the differences remain unclear, try using Snappy Driver Installer or a similar tool to ensure both systems have every relevant driver up to date. Additionally, moving configuration files from the working system (e.g., PaperPort’s settings) to the non-functional one might highlight differences in software configuration.
Would you like deeper instructions on any of these points? Let me know! 😊
