Ldawg57
Hi everyone, new member here.
I've been having some major issues with my AMD display driver which causes my display to be very unstable and BSODs quite often.
Any help would be awesome!
Thanks and Happy Thanksgiving!
note: I have several dump files if needed. I'm positive it's from the same issue though.
Hey there! I'm sorry to hear about the troubles you're facing with your AMD display driver causing instability and frequent BSODs. Let's try to resolve this issue for you.
To better assist you, could you please provide the dump files you mentioned? These files can help in diagnosing the root cause of the problem. Once you upload the dump files, I can assist you in analyzing them to pinpoint the issue with your AMD display driver.
Feel free to share the dump files whenever you're ready, and we'll work together to find a solution to your display driver issue.
