The user reports a fan failure alert from SupportAssist and seeks advice on replacement and BIOS updates, with some concern over their system's temperature readings. Several respondents advise that fans are generally replaceable, especially in desktops, and recommend updating the BIOS while questioning the reliability of the Core Temp app due to conflicting readings. Overall, the discussion reflects uncertainty about the actual hardware status, with suggestions to prioritize official diagnostics and updates over third-party temperature tools.
Fenway16
Honorable Member
Support Assist cane up with an alert this morning. Fan failure. Is that something I can replace with a little utube help.
IDPTF is an Intel driver that can limit your CPU to control thermal throttling, but also can be used along side power plans to make sure your laptop saves battery when in low power mode etc..
It's not a bad idea to update the IDPTF driver if it's out of date.
If you take it to a local shop (I own such a shop) I would have them test fan(s) under load, replace any that fail, as well as apply new (brand name good stuff) thermal paste on the CPU and GPU as needed (the factory stuff sucks, even in some brand new laptops). Long term damage can be done if you just keep running it at high temps.
Fenway16
Honorable Member
Thread Author #2
Went to Dell site - ran diagnostic - NO ISSUES - Can I assume all ok? It did come up with "urgent" BIOS update from April of 2020. Should I do that? Been running fine -- thanks.
Neemobeer
Windows Forum Team
If it's a desktop, they're pretty easy to replace. Laptops it just depends on the model and how easy they are to open.
patcooke
Microsoft MVP
Microsoft MVP
I'd run the BIOS update. If the Dell diagnostic reports ok (and if there is a fan problem I'd expect it to detect and report it) then I'd just see if any other problems arise. If the fan has/is failing you're likely to experience other problems cause by temperature - such as screen display memory problems, obscure errors etc.
Fenway16
Honorable Member
Thread Author #6
Just ran it again. Normal this time.
patcooke
Microsoft MVP
Microsoft MVP
I'd be having strong doubts about core temp app. If it's conflicting with Dell's software that's bad enough but if it's conflicting with its own reports . . .!
Fenway16
Honorable Member
Thread Author #8
So ignore Core Temp.? Ran it again - still ok. I am going to run support assist locally and see if it clears everything. Thanks.
patcooke
Microsoft MVP
Microsoft MVP
So ignore Core Temp.? If it conflicts with its own findings it seems to be very suspicious.
Fenway16
Honorable Member
Thread Author #10
I ran support assist yesterday. It came up with 3 driver downloads which I installed. No mention of fan problem at that time. So hard to know what's going on. Thanks.
Fenway16
Honorable Member
Thread Author #11
Did the bios update today. Core temp is showing 3 areas of overheating. I am going to take the back off and see if I can see any dust accumulation. That often causes overheating, right? I watched a utube vid and it doesn't look too difficult to remove cover - a lot of screws. Not sure what else to do about the problem. It seems very hot so I have turned it off for today. Thanks.
Fenway16
Honorable Member
Thread Author #12
I turned it back on and it is not overheating at all. It's been running for about an hour. I don't understand why hot sometimes and not others. I even played angry birds 2 which usually heats it up and it only heated a bit. Core temp did not flash a critical alert throughout the whole time. Hmmm.
Josephur
Windows Forum Admin
Sounds like you have a fan that is going on the outs, or it's sensor is going bad. Best to just replace it now and save yourself the headache later.
Fenway16
Honorable Member
Thread Author #14
So a system that is not even 2 years old - is already in need of medical care. I will look at utube to see how to do that. Thanks.
Josephur
Windows Forum Admin
If it's not even 2 years old it's possibly still under warranty?
Fenway16
Honorable Member
Thread Author #16
No - warranty one year only.
Fenway16
Honorable Member
Thread Author #17
So a fan or a sensor. That sounds like a computer repair shop. It still is running well below max temps - only when I play angry birds does it heat up. So I play a little and then stop. Otherwise no heating up for normal browsing etc. I am going to keep using it.
Fenway16
Honorable Member
Thread Author #18
Run a stress test on CPU & GPU in Dell Support Assist application & check if there is any thermal error detected.
Download & save Intel Dynamic Platform & Thermal Framework (IDPTF) driver from the support site.
Open device manager- expand IDPTF – right click on the driver & click on uninstall (check the box that says delete driver). Do not restart the computer, install the IDPTF driver saved on your desktop.
This was another help suggestion from a user to a user on the Dell site who was experiencing heat issues.
Anyone here familiar with the IDPTF driver - thanks.
Josephur
Windows Forum Admin
Josephur
Windows Forum Admin
Oh I almost forgot, it's also good to check what power profile you are using when plugged in to power, and unplugged. My guess is that shipped with a Dell preferred power saving plan applied, which is probably best. If the power plan gets corrupted, or is set incorrectly I have seen it cause issues. There are methods to restore the default Windows 10 power plans which work on most devices, but some really need the manufacturers profile to be applied.
Which Dell system is this exactly?
