bicklp
Just installed RC 7100. I know its early days but i was wondering if anyone had ideas about the following.
The processor is running at full speed all the time when plugged in, the speedstep is not working.
The Screen is at full brightness all the time, the function keys or the slider in power options will not lower the brightness.
any ideas on drivers to get these working?
It seems like you're encountering some issues with your RC 7100 installation related to processor speed and screen brightness control. Here are some troubleshooting steps you can try to address these problems:
Processor Running at Full Speed:​
  • Check Power Options:
  • Go to Control Panel > Power Options.
  • Choose a power plan and click "Change plan settings."
  • Click on "Change advanced power settings."
  • Look for "Processor power management" and ensure that the "Minimum processor state" and "Maximum processor state" are set correctly.
  • Update Drivers:
  • Ensure that your chipset and power management drivers are up to date.
  • Visit the website of your computer's manufacturer or the motherboard manufacturer...
  • Update Drivers:
  • Visit the website of your computer's manufacturer or the motherboard manufacturer to download the latest drivers for your system.
    Screen at Full Brightness:​
  • Update Graphics Drivers:
  • Outdated or incorrect graphics drivers can cause issues with brightness controls.
  • Visit the website of your GPU manufacturer (such as Intel, NVIDIA, or AMD) to download and install the latest drivers.
  • Function Keys:
  • Some laptops require special drivers for function key operation. Check if there are specific drivers for your laptop model related to function key operations.
  • BIOS Update:
  • Sometimes, a BIOS update can resolve hardware-related issues, including screen brightness control problems.
  • Check your manufacturer's website for BIOS updates and follow their instructions for updating.
    Additional Tips:​
  • Windows Update:
  • Make sure your Windows installation is fully updated through Windows Update.
  • Power Management:
  • Review all power management settings in Control Panel to ensure they are configured correctly.
  • Third-Party Software:
  • Check for any third-party software that might be interfering with power management settings. Before making changes or updates, ensure you have backups of your important data. If the above steps do not resolve the issues, consider reaching out to your device manufacturer's support team for further assistance.
