Brman
Hello,
I have been having these blue screens for a while after re installing windows, i have been getting mini dump files as well that i would appreciate if they got analysed, it would help as these are getting very frequent.
So if there is someone that knows what there doing with this sort of thing i would appreciate if they got analysed so i can maybe fix it.
Thanks,
Brman.
MtheK
From the most current dump:
* Bugcheck Analysis *
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
interrupt request level (IRQL) that is too high. This is usually
CURRENT_IRQL: 0
FAULTING_IP:
+62162faf034eda20
fffffa7f`f7000045 ?? ???
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xD1
LAST_CONTROL_TRANSFER: from fffff80002ed91e9 to fffff80002ed9c40
FAILED_INSTRUCTION_ADDRESS:
+62162faf034eda20
STACK_TEXT:
fffff800`00b9c128 fffff800`02ed91e9 : 00000000`0000000a fffffa7f`f7000045 00000000`0000000a 00000000`00000008 : nt+0x75c40
fffff800`00b9c130 00000000`0000000a : fffffa7f`f7000045 00000000`0000000a 00000000`00000008 fffffa7f`f7000045 : nt+0x751e9
fffff800`00b9c138 fffffa7f`f7000045 : 00000000`0000000a 00000000`00000008 fffffa7f`f7000045 00000000`00000000 : 0xa
fffff800`00b9c140 00000000`0000000a : 00000000`00000008 fffffa7f`f7000045 00000000`00000000 bcf7bd97`bcf7bd97 : 0xfffffa7f`f7000045
fffff800`00b9c148 00000000`00000008 : fffffa7f`f7000045 00000000`00000000 bcf7bd97`bcf7bd97 bcf7bd97`bcf7bd97 : 0xa
fffff800`00b9c150 fffffa7f`f7000045 : 00000000`00000000 bcf7bd97`bcf7bd97 bcf7bd97`bcf7bd97 3ddb487c`3f7e5024 : 0x8
fffff800`00b9c158 00000000`00000000 : bcf7bd97`bcf7bd97 bcf7bd97`bcf7bd97 3ddb487c`3f7e5024 00000000`3b3c4036 : 0xfffffa7f`f7000045
STACK_COMMAND: kb
FOLLOWUP_IP:
nt+75c40
fffff800`02ed9c40 48894c2408 mov qword ptr [rsp+8],rcx
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt+75c40
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntoskrnl.exe
Brman
CURRENT_IRQL: 0
FAULTING_IP:
+62162faf034eda20
BUGCHECK_STR: 0xD1
+62162faf034eda20
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
nt+75c40
Thank you! But now that i have this i don't know what to do. Is there a certain way i can see what the problem is or what is or what is causing the blue screens?
Joe S
Go to the BSOD section read the directions there and post the required items. there
Joe
