The original poster is experiencing frequent Wi-Fi connection issues with their mobile hotspot, often requiring a network reset to reconnect, which is stressful during exams. A detailed troubleshooting guide suggests steps like removing and re-adding networks, updating drivers, adjusting power and DNS settings, and testing different networks. Overall, the thread aims to help resolve persistent connectivity problems for a more stable internet experience.
kaczynski
So I always pair my laptop with my phone; use my mobile hotspot for the Internet. Lately, I have been experiencing some issues while reconnecting.
Say, for instance, I switch on my mobile hotspot, use the internet, then switch off my hotspot, take a break, and then again switch on and try to connect my laptop to my mobile network, It just won't work.
It'll say that it has established a connection. The wifi symbol becomes bright white(indicating a good connection), but the web pages will keep on buffering and will not load. I tried several settings from refreshing my network list, changing IP addresses, changing power settings, updating and re-installing wireless network drivers, etc. Nothing seemed to work. One day, I stumbled upon the network reset option, and it did the trick.
However, I'm tired of having to do a network reset almost every other day, to get back online, in case of interruptions. How do I fix this?
Any help will be appreciated as my exams are going on, and such problems are really stressful
Facing recurring connection issues with your mobile hotspot can indeed be frustrating, especially during crucial times like your exams. Here are some steps and tips to troubleshoot and address this problem:
Initial Troubleshooting Steps:​
  • Forget Network:
  • Remove the saved network profile from your laptop and reconnect to the hotspot network as a fresh connection.
  • Change Network Name (SSID):
  • Try changing the network name (SSID) on your mobile hotspot to ensure there are no conflicts with past connections.
  • Update Mobile Network Settings:
  • Make sure your mobile hotspot settings, especially security settings (password, security protocol), are correctly configured.
  • Reboot:
  • Occasionally...
  • Forget Network:
  • Reboot:
  • Occasionally, a quick reboot of both your phone and laptop can help clear network-related issues.
Advanced Troubleshooting:​
  • IP Conflict:
  • Check for any IP conflicts. Make sure both devices have distinct IP addresses.
  • Network Drivers:
  • Ensure your laptop's network adapter drivers are up to date. Check the manufacturer's website for the latest network adapter drivers.
  • Power Management:
  • Disable power management settings on your wireless adapter to prevent it from turning off to save power.
  • DNS Settings:
  • Manually set your DNS server addresses to Google's public DNS (8.8.8.8 and 8.8.4.4) on your laptop's network settings.
  • Network Troubleshooter:
  • Run the built-in Windows Network Troubleshooter to diagnose and fix common network connection issues.
  • Network Reset:
  • After the network reset works, it might indicate a deeper network stack issue on your laptop. Ensure you have your network settings backed up for an easy restore after a reset. If the problem persists, you may want to consider:
  • Alternative Hotspot: Try testing the connection with a different mobile hotspot or a Wi-Fi network to isolate whether the issue is with the network connection or the laptop settings.
  • Professional Diagnosis: Consult with a tech expert for in-depth diagnostics and solutions. By systematically troubleshooting these areas, you should be able to identify the root cause of the connection issues and work towards a more stable setup for your vital Internet needs, especially during your exams.
